Club RR Member Number: 160
Feb 12, 2020 18:05:23 GMT
I'll take some Probably be the weekend. I've just released, the bronze gear goes in the middle lol. I noticed from an earlier post, yours has a cover over the steering servo? Mine doesn't mention one either, but I have a feeling it's in the box somewhere. Yea, there’s no mention of the cover anywhere I’ve seen but my B36 had one but the C24 didn’t come with one. I just made a strap of tin type metal over the servo to retain it, it sits where it sits if that makes sense, it can’t go in wrong.
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Yes, I'll have to make something up I think I've also ordered a ton of lolly pop sticks to make some tat for the rear bed
vanpeebles
Feb 14, 2020 20:33:31 GMT
Still struggling with the axles, they bind up tight once the screws go into the diff covers.
Feb 14, 2020 21:50:15 GMT
Still struggling with the axles, they bind up tight once the screws go into the diff covers. Pinions need to be shimmed away from the CROWN, you could try making a gasket for the cover, some people have had success with that, or filing the back of the pinion to allow it to not jam the CROWN.
vanpeebles
Feb 14, 2020 21:53:53 GMT
I’ve just kept the screws slack for the moment, I might try making some gaskets.
vanpeebles
Feb 15, 2020 18:29:46 GMT
Feb 15, 2020 19:18:13 GMT
Nearly finished, front indicators and mirrors to do, plus not quite convinced by the front axle setup in the manual. The bars seem arl ower, and one is way too short. Truck looks great! Don't really have a lot of experience of the KM axle parts though, could they have supplied one wrong link in the kit perhaps? Oh, also, have a video. Only just got round to finishing the 'edit', if you could call it that.
vanpeebles
Feb 15, 2020 19:41:09 GMT
The vid is great! Really clear too! It’s strange, I followed the lengths on the instructions, I’ll have to search online a bit.
vanpeebles
Feb 15, 2020 22:50:55 GMT
I think the front has three main links, and a panhard rod which I’m not sure where it goes!
Feb 15, 2020 23:57:05 GMT
I think the front has three main links, and a panhard rod which I’m not sure where it goes! Had a look at the instructions, it’s a bit odd but yea, the front has a three link with panhard and the rear is a 4 link.
vanpeebles
Where would you say panhard connects too? It’s far too short to go where the three links go on the chassis.
Where would you say panhard connects too? It’s far too short to go where the three links go on the chassis. Goes in front of the axle looking at the instructions. Should be lugs on the front of the axle tube to mount it?
sowen
Club RR Member Number: 24
Nearly finished, front indicators and mirrors to do, plus not quite convinced by the front axle setup in the manual. The bars seem arl ower, and one is way too short. Should be 3 links with a panhard bar that attaches to the bottom of the servo carrier and the odd lug on the axle truss And you're weathering is amazing! I haven't really touched mine in a little while, need to carry on building the extended tray on my second C44, and I'm looking at modifying the tray that sits above the servo under the bonnet to give more space to fit the V3 electronics and maybe even the battery?
vanpeebles
Feb 16, 2020 10:45:30 GMT
That is perfect thank you! Did you have any trouble with the axles binding?
sowen
Feb 16, 2020 10:48:11 GMT
The first one I made was a bit notchy to start with, but that's cleared fine after a little use. The second one takes some effort to make it roll, but that's still in build and I need to make a custom lengthened rear propshaft for it before that can be driven.
vanpeebles
Feb 16, 2020 11:07:10 GMT
I'll try some gaskets and give it a good flog once I get some radio gear and stuff. First of the bed tat made!
sowen
Feb 16, 2020 14:12:47 GMT
That was more or less my plan, get the second one to roll then thrash it about until it sorted itself out.
I'd say it's worth getting a tap to start the thread in the servo tray where the ball screws in. On both of mine you could see the plastic on the outside whitening as I was screwing them in. Put a starter tap in (think those balljoints are M3) and went again and no issues. Enough resistance that it won't unscrew, and didn't feel like if I screwed it in all the way it would snap off!
vanpeebles
Feb 16, 2020 15:21:26 GMT
Good advice! I’ve not put the link in yet
vanpeebles
Feb 16, 2020 18:30:20 GMT
Bedtat done for now, in my old parts part, I had a wooden barrel, which I painted and highlighted like a plastic water barrel. And also an unknown part of an engine which was in that awful plastic chrome effect. I painted this black, then dry brushed with two shades of metallic. I might make some more of the small pallets just to stack maybe. I just need some scale ropes now to tie it all down!
vanpeebles
Feb 20, 2020 18:30:22 GMT
