Hi Rian, That really is a nice looking motor, have to agree that the "roof" panel for the truck bed will finish it off, (& probably make it a more useful feature with our climate,) Nigel
Jan 30, 2021 11:59:46 GMT
Like the 'blacked out' B pillar seems to visually lower the roof line nicely ...
Last Edit: Jan 30, 2021 12:00:10 GMT by westbay
Jan 30, 2021 17:18:04 GMT
Like the 'blacked out' B pillar seems to visually lower the roof line nicely ... Agreed, it's made the rear window look better, keeping the line flowing through.
Jan 30, 2021 17:43:50 GMT
I do Continue to be amused by this truck and finding little tweaks, not looking for my to do, they just pop up. And I have to respond. Seems like a reasonable visual illusionary idea.... Solution. Promptly followed by this bright idea. Will be interesting to do this as I did Prozac the Berlingo, and also the Non Project Blazer before with success. So what can we do today? Like the 'blacked out' B pillar seems to visually lower the roof line nicely ... I thought it was a small detail that GM could have used themselves, but it’s a cheap visual trick, and I am kinda cheap. Like the 'blacked out' B pillar seems to visually lower the roof line nicely ... Agreed, it's made the rear window look better, keeping the line flowing through. I,think it will work. Thankfully, if it is a failure, even with the glass tinting too, it’s still under £15.00 spent on cosmetics Well worth the risk. I think.
Jan 30, 2021 17:45:24 GMT
Hi Rian, That really is a nice looking motor, have to agree that the "roof" panel for the truck bed will finish it off, (& probably make it a more useful feature with our climate,) Nigel Thanks Nigel. I grew up with canopies, and they are nice, only if you get the right one, flow, colour etc. I think that if one had the teardrop hooked up, a canopy will look neat.
Jan 30, 2021 19:15:30 GMT
GM did do that on a number of vehicles of the era. We had an Impala that has the same treatment between the windows to change the look of the glasshouse.
It'll work.
Phil
Jan 31, 2021 14:23:54 GMT
You can also just put a resistor (usually around 50W) in parallel with the LED bulb to give the same resistance as the original bulb, some LED's include these already but obviously not yours. That was what I thought when I read “Plug and Play” Obviously not I had to wire in resistors on the Covin 912 when using LEDs.
Jan 31, 2021 16:35:21 GMT
GM did do that on a number of vehicles of the era. We had an Impala that has the same treatment between the windows to change the look of the glasshouse. It'll work. Phil I believe it will. Surprised more guys who tint their glass, do not do that as well. That was what I thought when I read “Plug and Play” Obviously not I had to wire in resistors on the Covin 912 when using LEDs. Will be done, soon as.
brachunky
Scotland
Club RR Member Number: 72
Jan 31, 2021 17:14:51 GMT
The truck has come along loads! Nice work Grizza.
Jan 31, 2021 17:18:13 GMT
Marmite. Chalk n Cheese. Give and Take. Wheels from other brands. Still have the hots for a set of these, I see they come as low as £120.00 for 4 with or without tyres. So with the 5x120 size here, a lot of non-GM wheels will be needing spacers to place them right in the arches. Yesterday afternoon around 5.00pm I saw some 5x120 BMW 20mm spacers with a 72mm centre bore on Marketplace for £20.00 including 9 bolts about 10 miles from here. The S10 uses Nuts, not bolts, so missing one was fine, and these can be used for trading again at some point. Contacted the seller to say I was interested but could only collect today if I went out for some hardware, and that he should sell them if another buyer came up. “Where do you live, I am headed out for some food shopping in a few minutes” Told him where I lived, and he said he would run by and just drop them off on the driveway en route to the grocery store. So half an hour later I traded, a pack of Haribo Mix for his kids in the car and some cash for him. Saved me 20 miles driving and specific planning. Nice way to end my day........; now to find something interesting to fit for winter wheels. (No, absolutely do not need them, you are right) Went to bed late, woke too early, by 05.00 so sat chatting with Dennis in St Louis about life and the 66 NASCAR C10 Truck build that is progressing. Later he went to bed and I went down for breakfast. Pleasant surprise outside. Rain had stopped, thankfully, as I had a few plans for today. Plan one for today was to fit the resistors over the LED indicator wires. One on each side. Front end disassembled again, easier every time as you learn your way around this truck. Outside was 3’C and shady, plus there was a brisk breeze, cutting through 4 layers, that was less than pleasant. This is the mess I found. Remember the wiring on the Blazer? That was certainly worse, and I got that lot tidied up. Tried to get the soldering iron warm enough to undo the joins the cowboy who did the original wiring “modifications” had done was fun, it actually did not get warm enough. Mate Martin had given advice remotely as well, as he speaks electrics in his sleep. But a bit of a struggle for my little brain overall. craigrk suggested I remove all the mess and use some of these plugs units. So I ordered them off eBay for delivery next weekend.and will solder in new wires and connections. Reassembled. Amber bulbs fitted temporarily. After this I came in to warm up and also had a delivery. One more small job left to do a bit later.
Last Edit: Jan 31, 2021 17:29:20 GMT by grizz
mk2cossie
Club RR Member Number: 77
Jan 31, 2021 18:47:28 GMT
Is that a side light in the headlight unit grizz? If it is, then the Amber lights in the indicator units is fine
glenanderson
Club RR Member Number: 64
Jan 31, 2021 18:49:41 GMT
If you’re going to use those connectors, which are ideal by the way, then invest in a crimping tool to just crimp the terminals on properly. Don’t fox-picture about trying to solder them.
Jan 31, 2021 18:52:07 GMT
Is that a side light in the headlight unit grizz? If it is, then the Amber lights in the indicator units is fine Hell, I don’t know. Outside corners? Will check some time, cold and raining now, and a bit dark.
Jan 31, 2021 18:54:25 GMT
If you’re going to use those connectors, which are ideal by the way, then invest in a crimping tool to just crimp the terminals on properly. Don’t fox-picture about trying to solder them. I am , well I was sure I had/have one, could not find it today, you have seen my garage. But thinking of it now, it may be somewhere else. Will looks again, pretty certain Imbought a box of fittings nd a,tool, if not, cheap enough.
mk2cossie
Jan 31, 2021 19:36:01 GMT
Is that a side light in the headlight unit grizz? If it is, then the Amber lights in the indicator units is fine Hell, I don’t know. Outside corners? Will check some time, cold and raining now, and a bit dark. From the video of the clear light units fitted with the Amber bulbs, it "looks" like there is a marker light on the very outer section of the headlight unit If so, fit the amber bulbs and don't worry about the faff of the resistors
Hell, I don’t know. Outside corners? Will check some time, cold and raining now, and a bit dark. From the video of the clear light units fitted with the Amber bulbs, it "looks" like there is a marker light on the very outer section of the headlight unit If so, fit the amber bulbs and don't worry about the faff of the resistors There are small lamps in the top corners yes. And then of course the driving beam, and high beam. Low Beam High Beam. .
93fxdl
Enter your message here...
Maybe this would have sorted your indicators Ttfn Glenn
Club RR Member Number: 160
Seeing as you DO have side markers in the main lamps it seems you can use the amber on ambers if you wanted or you can obviously fit your switchbacks.
Seeing as you DO have side markers in the main lamps it seems you can use the amber on ambers if you wanted or you can obviously fit your switchbacks. I love the switchbacks. Firstly the white light forms part of the DRL and then the novelty of having them. Nope, they will stay.
Been a bit busy with the day job. Small jobs. This one took about 6 minutes in total. . I hear Paul Y clapping now. And they are ready to be off to Hampshire And in their place will be a set of original manufacturers specification lights. Personal choice yes. Remember how pitted my battery tray was, lots of holes rusted through. Reached out to Robert, they guy selling me an original steering wheel, and asked if he maybe had one in better condition. He went through his scrap pile nd found this one, needs a bit of cleaning and painting, but looks better than mine. Saw this truck for sale on FB today. In case someone needs one. 145k miles and £6750.00 And so that is all for today. Bit by bit.
Last Edit: Feb 1, 2021 20:44:20 GMT by grizz
