May 13, 2020 18:26:01 GMT
They were on my to-do list, as you say they don’t look like they can handle a lot, but having broken one they’ve moved up the list Mine are bolt on ones I think, 18mm nut to ARB and a plate and bush either side of the lower arm I am pretty happy with my repairs, they could no doubt be done better, but it looks ok, the paint is letting it down mostly I think, Could be tidier inside, the strip jointing the new inner wing panel to the inside of the van panel... but it’s been a learning experience and I know what I’d do differently next time (and it can’t be seen anyway ) I keep reminding myself that it’s at least strong and metal now!
May 15, 2020 18:54:06 GMT
Fitted the drop links, replacement handbrake cable turned up. I replaced this just before lockdown because it snapped. Not sure if it was just a shonky part from ECP or if it was the wrong part supplied. I have been told there are 4 different handbrake cables; hatch and estate and either drum or disc So it’s possible that I had one of the other variants, anyway one side was too short and wouldn’t fit into the support, and the other too long and was resting on the exhaust. This one fits ok, not a great or interesting photo... And where it was melting on the exhaust And took a photo of it loaded with my stuff
May 16, 2020 15:09:31 GMT
I think I’m ok saying this in here, I suspect others will understand and not judge me too harshly The o/s strut was really rusty, we couldn’t get the top cap off to remove the damper at all, so I ordered a couple of secondhand ones. They turned up and I rebuilt them and they are fitted. But, the original ones had 74x39x39 bearings, which I was led to believe were fitted to the later (post ‘96) heavier (so bigger petrols and diesels) small block struts (not gsi, Isuzu diesels because they are big block struts (and have 28 spline driveshafts)) One of the replacements (the o/s) was the same size, but the other one, the n/s bearing size was 66x34x34, not a deal breaker and it is fitted on the van, but the engineer in me doesn’t like it. So since I hadn’t looked at the n/s strut I thought I’d give it a go. So welded a bit of bar to the cap and got brutal Taa-daa I got it off (the other bits of weld are from trying to do the same on the other one... that one really doesn’t want to come loose I then cleaned it up The spring seat is pretty good, obviously I need to pop the hub and bearing out, but will work that in with using a press somewhere Gave it a coat of hydrate80 And packed up.... might get in trouble for the mess on the lawn though I ordered a pair of bigger bearings, so can rebuild it ready to go. One of the top bearings is playing up a bit, as sometimes the wheels is a bit slow to centre, or pulls a bit, I’ve ordered some of those so depending on timings it may get swapped when I do that
May 19, 2020 15:50:15 GMT
We are still supposed to be making essential journeys only! Today I drove to Kings Lynn and back. Client of my customer wanted their weighbridge reinforcing, so the lads went in, climbed under the bridge to disconnect the load cells (they don’t like being welded near) and were about to start welding when the client stopped them because the on-site electrician was unhappy that they couldn’t show the last PAT test. So I drove over to the site this morning to do some PAT testing....... now you may, like me, have had a thought about how we could have prevented my trip over, but if common sense didn’t prevail yesterday, it wasn’t going to today So, couple of hundred miles, left around 5, and left Kings Lynn at 10.30. By then it was warm, had to wind the window down and trundle back. The site wasn’t very pretty, here is a photo out on the Fens in the sunshine Also found out the site is closing in 3 months anyway!! I do enjoy driving it, I may need to add swapping the drivers seat to the bottom of the list though, it wasn’t terrible, but could definately be more comfortable, I think the foam may have gone Got home and collected the VW to drive 5 miles and pick up a tonne of topsoil. A big van does have some advantages! I refused to use the aircon though, don’t want to get soft again
May 19, 2020 16:22:51 GMT
Sport or GSi seats bolt straight in, as do Cavalier and Calibra (nice leather in a Calibra) if you swap the sub frames over. My GSi seats are hands down the comfiest seats I've ever had, Scotland and back from North Wales no issues.
May 19, 2020 20:01:54 GMT
binge read catch up great work. those ring nuts that hold the damper in are done up to 200NM (148lbs) the second tightest nut on the entire car !! (after the crank bolt) its not bad luck to require extreme force to get them off, and the reverse is necessary on the new items too, for safety
Last Edit: May 19, 2020 20:03:10 GMT by darrenh
May 19, 2020 20:09:10 GMT
binge read catch up great work. those ring nuts that hold the damper in are done up to 200NM (148lbs) the second tightest nut on the entire car !! (after the crank bolt) its not bad luck to require extreme force to get them off, and the reverse is necessary on the new items too, for safety I put the big stilstons on them, not sure they are 200nm though. Going to change the top mounts anyway, it was misbehaving and not centring the wheels at the weekend so wondered if I’d pinched one on reassembly, so ordered a pair and will swap them soon (think the bits are due tomorrow or thursday and Lucy is working Thursday and Friday, so probably one of them depending on weather) but I’ll double check them when I disassemble anyway now And thanks
May 19, 2020 20:15:18 GMT
And they are getting ready for next flock at the farm, so I’ve got some things to do there. Popped up today and changed the bearing in the other strut whilst there. And as a short term fix, wondering if I can rob some bits out of the hotbox corsa seat. Looking at photos they look pretty similar, certainly in terms of shape if not the actual fabric. I can strip the Corsa one anyway and it’ll give me an idea of what I need to do later regardless. So will pick that up next time I go up (which means now after 5 months he will collect it before I get up there )
May 22, 2020 18:19:24 GMT
Pretty sure I spotted this in oxford today? It stood as as you don’t see many of this age on the road anymore
- '88 MK2 Golf 1.3 c - '07 BMW E91 335d - '94 T4 1.9d
May 22, 2020 18:37:49 GMT
Pretty sure I spotted this in oxford today? It stood as as you don’t see many of this age on the road anymore You did indeed Was working on a house on Long Lane
May 22, 2020 21:21:42 GMT
That’s where I saw it, like the look of it on the bigger steels 👍🏻
May 22, 2020 21:28:20 GMT
That’s where I saw it, like the look of it on the bigger steels 👍🏻 It’s still on standard 14s at the minute, but with lowering and the centre cap hub caps I think it looks better too!
May 26, 2020 11:04:04 GMT
I didn’t post at the weekend, I was a bit traveller and thought if I admitted it I would jinx it On Sunday Tom helped me swap the top mounts..... or at least we started. We took the drivers side strut apart and as we pushed the driveshaft out, it pulled the bearing to bits So being all forward thinking, I’d bought a spare wheel bearing when I ordered.... Yay and then rebuilt the other strut with that bearing last week....... boo It was Sunday, nowhere open, nearest gsf had them in stock, but were closed Sunday and the bank holiday, and I had agreed to work on the bank holiday and needed my huge ladders... So we changed the top mount, and I hammered the bearing back together! and we put it together and hoped Monday I did an impression of a fire engine And drove 15 miles, and 15 miles home.... not sure if the noise was the ladders on the roof or the wheel bearing. It felt a bit warm but was ok. Was going drive 5 miles today and pick up the bearing later on and fit tonight, but today’s job got cancelled so I picked a pair of more expensive bearings up from GSF (don’t think they were better, just that I paid more ) and fitted one this morning with Tom Luckily, after the kerfuffle of trying to use people’s kit with all the lockdown stuff, I bought a 10 ton press last week, so we built that at the weekend in readiness It’s a bench one, and as we found out today, it’s a little bit of a pain as the hub doesn’t drop through the frame like the big one at the farm... but meh! it’s here and so a small inconvenience is payment. Got a bench one so it will fit under some shelves at the back of the garage* Just need to tidy up the rest of it and I’ll be useable.... but that’s a job for another day Also, got some pattern back plates, painted them up in readiness They didn’t fit, and I couldn’t work out why, so left them off... but the rusty strut had the rusty remnants of one on there Aaaaaaannnnnnndddd they are just pattern bits, so will modify and fit at the weekend (don’t need to remove the strut to do that at least (yay!!!! ) but will need to remove the other strut to change it and will swap the other top mount at the same time.... what could possibly go wrong I’m calling it a garage, it’s 8’ x 6’ but is situated where a garage would have been if we had the space!
May 26, 2020 11:55:56 GMT
There were 2 sizes of back plate, 100mm or 87mm internal diameter depending on engine size, those are probably for the smaller petrol engine models
May 26, 2020 16:20:41 GMT
There were 2 sizes of back plate, 100mm or 87mm internal diameter depending on engine size, those are probably for the smaller petrol engine models That would make sense..... I’ll just make them fit for what they do.... especially as I went to all the trouble of etch priming and painting I also got around to changing the gauge temperature sensor over the weekend. I had shorted it out to check it was the sensor ages ago and got a replacement and then forgot about it A triumph of engineering wedged into a corner where only a spanner would fit and I could turn it a tiny amount at a time, and then wriggle it out because there is an injector right behind it (but I guess it doesn’t need changing often) I also replaced the alternator belt, that had started squealing on Friday (a week or so after the cam belt was changed, it had worked loose) but I’ve been meaning to swap it since I got the van, but adjusted it and it stopped, so as I left a site on Saturday morning and it was screaming, I stopped swapped it and chucked it in the skip
bstardchild
Club RR Member Number: 71
May 26, 2020 22:40:52 GMT
And drove 15 miles, and 15 miles home.... not sure if the noise was the ladders on the roof or the wheel bearing. It felt a bit warm but was ok. Was going drive 5 miles today and pick up the bearing later on and fit tonight, but today’s job got cancelled so I picked a pair of more expensive bearings up from GSF (don’t think they were better, just that I paid more ) and fitted one this morning with Tom Under the car with an RR event t-shirt on - Oh my days that's not way to treat what will one day be a collectable item*................. * Maybe......... I keep all mine for "best" - even my 2008 one is still relatively good condition if a little faded
May 26, 2020 23:03:10 GMT
Thats some MIGHTY work there. I think I would have given up long ago WELL DONE
Under the car with an RR event t-shirt on - Oh my days that's not way to treat what will one day be a collectable item*................. * Maybe......... I keep all mine for "best" - even my 2008 one is still relatively good condition if a little faded I hadn’t noticed that, I’ll bring it up at his weekly thrashing Mine are for best too..... there was a dodgy point in our relationship a loooonnng time ago where Lucy threw a knackered holey tee shirt away and we nearly broke up
Thats some MIGHTY work there. I think I would have given up long ago WELL DONE This lock down saved it, given more freedom I may have given up too, I’m really pleased I haven’t though
Front wheel bearings of that type always do that when you press the hub out. Nothing to worry about. Stick it in the vice,cut the inner bearing race nearly all the way through with a slitting disc. One sharp knock with a chisel and a BFH in the newly slit,slit and it will split the inner race and fall off🤣🤣 Just be careful when you press the new bearing in. Make sure to press on the outer race when you push the bearing into the upright,and make sure you have something supporting the inner race when you press the hub in. Otherwise the hub will vandalise the new bearing to death and it will suffer from separation anxiety....
Last Edit: May 27, 2020 6:21:21 GMT by Deleted
