x4 std c20xe con rods £25 plus p&p
C20let std oil cooler £15 plus p&p
C20let std inlet manifold (bare) £15 plus p&p
Std C20let top hat £25 plus p&p
Std c20xe throttle body £30 plus p&p
C20xe oil pick up pipe £15 plus p&p
Std 3 way coolant hose £8 plus p&p
front fog lamps (cav Sri I believe) will have to be checked against part numbers £10 plus p&p
6 pin MAF sensor £30 plus p&p
Cav mk3 PAS steering rack, PAS pipes, PAS pump & reservoir £80 plus p&p
X2 C20xe ECUs (unsure if chipped, will check) £50 each plus p&p
C20xe wiring loom (will need to check whether dizzyless or
Not, plus has x1 loom connector broken) £50 plus p&p
C20let wiring loom, ECU & piggy back ECU set £120 plus p&p
Std air filter housing c20xe from cavalier I believe, again need to check from part number £15 plus p&p
C20xe silicone hose crankcase breather £8 plus p&p
C20xe/let distributor with red leads (x1 lead missing) will check which £40 plus p&p
Ignition coil (for dizzy) £10 plus p&p
X2 C20xe ignition module £10 each plus p&p
C20xe inner metal cambelt cover (unsure how to tell difference on early or late, hopefully someone can help there) £15 plus p&p
C20xe fuel rail with beige injectors £10 plus p&p
Cav mk3 coolant tank £8 plus p&p
UNTESTED 13 row oil cooler £10 plus p&p
X3 cav turbo door cards grey carpet with wooden trim (complete minus drivers front)
£35 plus p&p
Cav/Astra f 5 speed gear knob average condition £5 plus p&p
Have a look here
www.migweb.co.uk/threads/various-c20xe-c20let-cav-mk3-bits.785875/
£35 plus p&p
Have a look here
