Hi. I'm working on something called a Fiberfab Jamaican. It's an American fibreglass body on an Austin Healey 3000 ( pictures to follow) Two things I'm thinking about just now 1) I intend to create an opening bootlid - cut out and bond in hinges etc. My question is, any good ideas for forming a flange that will accept a rubber seal ? A sort of U section I suppose that will have a mall drain built in at the bottom. I just haven't thought a way to make something to mould over. 2) there isn't enough headroom in the car ! Sitting on the floor, my head brushes the roof. I will be using a fibreglass seat bolted to the floor which will be as thin as possible under my bum. I can't go down any, cos there's a chassis leg under the seat. I could do a " Gurney bubble " but I really don't want to spoil the lines. Hopefully you will see from the photos. As it's fibreglass, I could cut out and raise the roof I suppose but again, I don't want to spoil the looks Any suggestions / thoughts welcome, especially those that don't involve surgery on me !
Darkspeed Has a fleet of glass fibre based cars & projects on here - maybe he could advise you - certainly never seen one of these before today
Always liked these Regarding headroom, is there no way you can recline the driving position more, to avoid the need to raise the roof?
Last Edit: Apr 8, 2020 22:08:19 GMT by Paul H
scimjim
Club RR Member Number: 8
Is it a “Chassis leg” under the seat, or an outrigger to the side rail? I’ve dropped the floor on a few of my GRP cars and I just weld a new outrigger on lower down and/or move it back slightly. On the one I’m currently doing, that’ll involve using thicker metal and making the U section narrower.
There just isn't room to recline enough and get a good driving position. The main longitudinal chassis leg runs right under the seat, and the crossmember that supports the front of the leaf spring is in the way too. It's a tricky one !
moglite
Club RR Member Number: 144
Glassfibre moulding questionsmoglite
@moglite
Club Retro Rides Member 144
The windscreen could stand with being a little more upright, but the back 3/4 view is gorgeous, and would be tricky to keep with a raised roofline.
Can you move the pedal box forward, to get more recline ?
1967 Morris Oxford Traveller 1979 Toyota LandCruiser BJ40 1993 Daimler Double Six 2007 Volvo XC70 2.4D
moglite
@moglite
Plan B - space the body 2" off the chassis to give you the room you need, then rework the wheelarches to suit ?
scimjim
There just isn't room to recline enough and get a good driving position. The main longitudinal chassis leg runs right under the seat, and the crossmember that supports the front of the leaf spring is in the way too. It's a tricky one ! That’s a bummer! A pair of Gurney bubbles matching the side profile, could look quite good?
I really don't fancy the idea of hugely reclined seats. I could raise the body on the chassis, but I see nightmares trying to get the wheelarches ( and a lot more ) to work. I may well give that a go before I bond the body to the chassis though. Otherwise it'll be the twin Gurney bubbles. Still to figure the boot seal fabrication tho. I've had an interesting suggestion involving plastic conduit Thanks all. Keep em coming !
jpr1977
Club RR Member Number: 18
Glassfibre moulding questionsjpr1977
@jpr1977
Club Retro Rides Member 18
Have a look for GRP Pultruded section suppliers to see if you can find some Channels/angles to suit your need for the fab of a boot lip/seal etc. something like; GRP PultrusionsThis would be more effective than trying to tie together plastic conduit and GRP. Where about's are you? The originator of fibrefab sounds a 'character' Warren Goodwin
Goodwin was a former sports-car racer and a keen fisherman, born in 1921 or 1922.
His earlier company, Sports Car Engineering, had manufactured Microplas Mistral bodies under license and sold them as the Spyder. He founded Fiberfab in 1964. In 1967, Goodwin was arrested on suspicion of murder for shooting his 28-year-old second wife, Jamaica. The police said he had found Jamaica with Farbus Kidoo. Goodwin claimed the shooting was accidental. He was charged with the voluntary manslaughter and sentenced to 12 months' imprisonment. He died in jail on December 26, 1968, of a heart attack.
Last Edit: Apr 9, 2020 22:23:19 GMT by jpr1977
Apr 10, 2020 11:32:21 GMT
I'll investigate that company, thanks I may well try to raise the body on some wood blocks and see what problems it raises ( see what I did there ! )
Apr 10, 2020 14:58:47 GMT
You'll never get it to look correct. To save you the worry and wasted effort I'll take it away for you.
Apr 10, 2020 21:28:17 GMT
I propped the body about 30mm off the chassis today. Looks like it might work, but gives me a whole lot of glassfibring to do I also discovered something called a " flexible French curve " which may help with my boot flange
