Right, looking for some help.
Plan to use CarBuilderSolutions' Mini Bear 75mm Claw Door Latches.
Before I reinvent the wheel, I want to pick your brains or check that someone hasn't already sorted a solution.
I need to activate the latch from the outside but the lever works at 90 degrees to the door button movement.
I have worked out how to do it using a lever and fulcrum, but this problem must have surfaced before. Is there an off the shelf adaptor or, failing that, plans for an adapter out there?
