I am in urgent need of some help with some wheels. I seem to have suffered two flats which seem to be untraceable, the tyres seem good, valves replaced, no obvious punctures or perishing so I suspect the fault is actually within the alloy wheel itself with a possible crack or lifting of the powder coat which is allowing the pressure out over a period of a few days.
As such I am reluctant to put a new set of tyres on the car to discover that it is the wheels at fault. So I am in need of some new wheels and legal tyres.
As cheap as possibly ideally.
They will be going on a Volvo, which is 5x108, however I can use wobble bolts and also run 5X110 or 5x108.
Jaguar, Ford, Saab, Alfa and Vauxhall all seem to utilise a variation of the above PCD.
If you have anything suitable, please drop me a line. I am not in total desperate need, but could do with some sooner rather than later.
I am located in the south east.
Thanks.
Thanks.
