May 20, 2020 13:11:40 GMT
I haven’t tried it, but a mate with a s1 landy swears by a halfrauds product which is a freeze spray, can’t remember what it’s called but it’s an aerosol spray which contracts the seized fixing rapidly and makes it let go Did a quick search and couldn’t find it, anyone know about it?
Phil H
Club RR Member Number: 133
May 20, 2020 13:26:59 GMT
adam73bgt
Club RR Member Number: 58
May 20, 2020 14:36:24 GMT
May 20, 2020 15:23:19 GMT
Yeah that’s the one adam73bgt, if they don’t do it anymore that’ll be why I couldn’t find it. I guess were not allowed to play with stuff that might hurt us again 🙄 Maybe Phil h ‘s suggestion would work ?
Phil H
There’s also a Loctite version but not widely available, hence didn’t mention it.
I think the Halford Release spray isn’t thermal, just a normal releasing fluid. Who makes it, and hence how good it is I’ve no idea.
mht
Club RR Member Number: 185
May 21, 2020 10:00:59 GMT
Thanks guys, lots to follow up on there! I'm planning on pushing the car out of the garage at the weekend as it is a bit easier to get access. I'll see how the WD40 has worked but I'm only one mile from a Screwfix and they have some of the stuff Phil H suggested in stock. I thought about getting some locking pliers too to put on the nut as it is tricky to get a good grip on it whilst trying to turn the nut.
Mark
1977 MG B 1992 Lexus LS400 1998 VW Golf VR6 1999 BMW 740i
May 21, 2020 17:08:53 GMT
Give the starter motor a couple of decent whacks with a hammer then try it.
If not and the earth bolt still won't undo get your jump leads and put one from the negative on the battery to a clean bare metal bit on the body then the other one from the engine to a clean bare metal bit on the body. If it then starts it's a earth issue to sort.
If it doesn't start bridge the terminals on the starter with a big screwdriver. If it turns over it's a issue with the ignition wiring or switch. If it doesn't and there are sparks it's a dead starter motor. If it doesn't and there aren't sparks there's a issue with the battery cable to the starter.
Though first things first - make sure it is definitely in neutral and put some big chocks/bricks infront of the fronts wheels. I know a couple of people who've had their legs crushed by doing the above whilst the car is in gear and it's driven them into the garage wall.
mht
Sept 12, 2020 20:46:20 GMT
Well it only took three months. One year olds twins, working from home and general chaos meant that the MG got pushed to the back of the queue and I put the car on SORN. This weekend my wife took the children to her see her parents so in anticipation I ordered a few bits from Moss and put the battery win charge last night. First job was to dig the car out. It basically became a table. After clearing the car and pushing it out I could have a go on the headache bolt gain. Here's the suspect earth cable. I still couldn't get it to do anything apart from spin around so I went to Screwfix. Finally started to get somewhere. The washer came off first then bit by bit I got the rest off. Then got the new one on easily. As suggested I cleaned the battery connections and but on some battery grease - and hey presto, it worked! Thank you for all the comments and pointers, I took it for a trip to Oxford on the back roads and there was no sign of any clicking on any of the startups.
Mark
