I am after a pair of calipers for the 256x24mm discs on the front of a Vauxhall. Doesn't mater on condition and I would take just the carriers as recon calipers are available but the carriers are not.
They were fitted to many mk2 asta's, cavaliers, calibra's and early vectras often refered to as redtop calipers. Popular upgrade in the day for nova's / corsa's and various other cars.
Needed for a brake upgrade on my Opel Manta if anyone has some kicking around in their garage/shed etc
May 18, 2020 16:07:38 GMT
I’ve got a set of Astra mk3 1.7td front calipers and carrier’s. I’ll get a pic in the next few days
Can you not use the earlier Delco sliding caliper that does not need the separate carrier? it comes as a complete assembly ready to bolt on
May 19, 2020 20:18:32 GMT
I’ve got a set of Astra mk3 1.7td front calipers and carrier’s. I’ll get a pic in the next few days Yes please if they were 256mm discs Can you not use the earlier Delco sliding caliper that does not need the separate carrier? it comes as a complete assembly ready to bolt on No because they are not for a 256mm vented disc.
May 21, 2020 16:36:15 GMT
Err yep they are for 256mm by 24mm discs, all Astra MK2 1.8/2.0 and Cavalier MK2 SRI130 all ran 256mm discs and used the Delco caliper
Err yep they are for 256mm by 24mm discs, all Astra MK2 1.8/2.0 and Cavalier MK2 SRI130 all ran 256mm discs and used the Delco caliper Do you have a link to one of these delco calipers? I've only ever seen the ATE calipers listed for 256mm vented discs and i cannot find the caliper you mention with an ebay search anywhere. The only Delco calipers i can find are for solid discs
May 23, 2020 12:47:43 GMT
The part numbers are 3487992 or 93172976 or LC3505 for the right hand and 3487991 or 93172974 or LC3504 for the left hand
