markm3
May 18, 2020 10:56:11 GMT
Just thinking what options would be available to convert a rootes arrow model. Not necessarily going to happen soon but was thinking for simplicity BMW straight 6 (e46 era) perhaps S50b34. Obviously brakes to think of aswell. Thoughts and advice please.
92 miami 205 gti6 / 1994 m3 coupe a/c extras/coilovers/carbon csl boot
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
May 18, 2020 12:02:39 GMT
I’m sure someone on here fitted a Mazda MX5 unit in a Hunter, not sure who though.
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
markm3
May 18, 2020 12:33:15 GMT
Thanks for the reply. I do seem to recall the mx5 swap somewhere on here. Just seen a video on utube of a 4litre bmw engine conversion. Just one video added 9yrs ago though.
scimjim
Club RR Member Number: 8
May 18, 2020 12:50:54 GMT
If you’re after simplicity I’d go Saab, zetec, Duratec, MX5, GM, Merc four pot, or maybe a smaller V6 like the KL or GM if the engine bay has the available width? Maybe a ford/volvo 5 pot rather than 6? Gearbox/adaptors cost and availability can become an issue if you’re looking at anything that isn’t OEM RWD such as the zetec.
Phil H
Club RR Member Number: 133
May 18, 2020 14:43:11 GMT
Based on the engine bay size and heritage (plus the need to clear steering boxes and linkages..), if it fits a Mk2 Cortina, it should fit an Arrow. From what I recall, the bay isn't actually as wide as you'd think, so you'd probably need an upright 4-pot, so maybe not BMW or Merc? Ford, GM or (if it clears the steering bits) MX5 would be my thoughts based on availability. GM and Mazda will probably a lot cheaper to buy the bits (i.e. a whole car) especially given you can buy a running MX5 or Omega for less than the price a Ford Type 9 goes for these days..
May 18, 2020 14:52:49 GMT
As its Rootes perhaps look at the XU9 from Peugeot and I recall that it can be mated to the LT77 out of a 1.9 LDV Sherpa/200 (might be wrong on that though) to give the RWD configuration...
2014 - Audi A6 Avant 3.0Tdi Quattro 1958 - Chevrolet Apache Panel Truck 1959 - Plymouth Custom Suburban 1952 - Chevrolet 2dr Hardtop 1985 - Ford Econoline E350 Quadravan 2009 - Ovlov V70 2.5T 1970 - Cortina Mk2 Estate 2007 - Fiat Ducato LWB 120Multijet 2014 - Honda Civic 2.2 CTDi ES
markm3
May 18, 2020 15:14:10 GMT
As its Rootes perhaps look at the XU9 from Peugeot and I recall that it can be mated to the LT77 out of a 1.9 LDV Sherpa/200 (might be wrong on that though) to give the RWD configuration... Does the XU9 include the 406 petrol turbo? I have an xu10j4rs in my 205
markm3
May 18, 2020 15:16:29 GMT
And probably a daft question but is it best to put something in that is originally longitudinal in the donor vehicle?
Phil H
May 18, 2020 15:39:40 GMT
As its Rootes perhaps look at the XU9 from Peugeot and I recall that it can be mated to the LT77 out of a 1.9 LDV Sherpa/200 (might be wrong on that though) to give the RWD configuration... Does the XU9 include the 406 petrol turbo? I have an xu10j4rs in my 205 Pretty sure all XU engines have the same bellhousing pattern so theoretically, yes.
Phil H
May 18, 2020 15:43:10 GMT
And probably a daft question but is it best to put something in that is originally longitudinal in the donor vehicle? Saves possible headaches with flywheels, starter motors, spigot bearings, clutches, water pipes, engine mounts...as well as gearboxes. Transverse engines tend to "spread" sideways from the block so the ancillaries can be quite a way away from the centreline as well as be at a lower level. Not handy if your engine bay is narrower at the bottom than the top.
dazcapri
North East
Enter your message here...
May 18, 2020 17:45:55 GMT
I’m sure someone on here fitted a Mazda MX5 unit in a Hunter, not sure who though. Its Hillmanjames you're looking for
Mk3 Capri LS
It was me that fitted the mx5 lump into the hunter. It fitted in very easily from what I remember. No cutting of the transmission tunnel required, just a new gearbox mount to cobble up. Hardest part is getting someone to sort the propshaft out. There's photos on here and some more on my Instagram Hillmanjames Any questions let me know James Edit: here's the link to my thread... forum.retro-rides.org/thread/166310/hillman-hunter-megasquirt-wider-arches
Too many projects, not enough time.
