May 21, 2020 19:10:44 GMT
Evening all Anyone know if it’s possible to get a clutch cable for a ford Sierra with a type 9 that’s approximately 10 inches longer than standard? Thinking out loud here, but involves a zetec, a LHD Bellhousing and a starter motor side swap TIA
May 21, 2020 20:02:13 GMT
Would one from a Granada work?
Would one from a Granada work? Not sure if they’re any different to the Sierra ones, main issue is that the clutch fork obviously changes sides too, so cable will have to run under engine, and there’s the problem
I believe transit cables have the same ends to. Your best bet would be a call to burton power, they can tell you the length of all the cables.
Last Edit: May 22, 2020 6:43:45 GMT by carat 3.6
Hadn’t thought of that, thanks @carat 3.6
I know people like Speedy Cables and Speedograph Richfield will do "special edition" cables, if you need a different length for example.
JJ Cables near Coventry have done several custom clutch cables for me.
May 22, 2020 11:36:10 GMT
Thanks all, it appears that 2.3 diesel sierras have the fork on the other side, so investigating that. It’d be nice to have a standard part
scimjim
Club RR Member Number: 8
Obscure clutch cable question scimjim
@scimjim
Club Retro Rides Member 8
May 23, 2020 10:15:27 GMT
What does the pedal fitting look like, and what’s the length of the standard item?
Obscure clutch cable question Dez
@dez
Club Retro Rides Member 34
May 23, 2020 10:31:54 GMT
Some LHD variants Have absolutely ridiculous clutch cables. The one on my Citroen pickup that ran a mt75 and pinto was out of a LHD transit and was over 6foot long. Went all the way to the front of the engine bay and back again in a big loop.
May 23, 2020 10:41:22 GMT
Some LHD variants Have absolutely ridiculous clutch cables. The one on my Citroen pickup that ran a mt75 and pinto was out of a LHD transit and was over 6foot long. Went all the way to the front of the engine bay and back again in a big loop. Well at least there’s no kinking then 😀 I’d rather too long than too short scimjim it’s the standard ford issue ratchet and pawl at the pedal end. I’ll have to find the old cable and measure it,
@dez
May 23, 2020 11:42:54 GMT
Some LHD variants Have absolutely ridiculous clutch cables. The one on my Citroen pickup that ran a mt75 and pinto was out of a LHD transit and was over 6foot long. Went all the way to the front of the engine bay and back again in a big loop. Well at least there’s no kinking then 😀 I’d rather too long than too short scimjim it’s the standard ford issue ratchet and pawl at the pedal end. I’ll have to find the old cable and measure it, Yeah, I thought if you get one that’s miles to long it’s easy to shorten to fit.
scimjim
@scimjim
May 23, 2020 14:39:14 GMT
Some LHD variants Have absolutely ridiculous clutch cables. The one on my Citroen pickup that ran a mt75 and pinto was out of a LHD transit and was over 6foot long. Went all the way to the front of the engine bay and back again in a big loop. Well at least there’s no kinking then 😀 I’d rather too long than too short scimjim it’s the standard ford issue ratchet and pawl at the pedal end. I’ll have to find the old cable and measure it, I don’t know what the ford pedal end looks like. The Small Sports Scimitar has a type 9 and I don’t think they changed bellhousing a when they made LHD cars but changed the cable. The Reliant pedal end looks like this:
Last Edit: May 23, 2020 14:40:30 GMT by scimjim
May 23, 2020 14:46:18 GMT
The bellhousing on the sierras is the other way round on the LHD to RHD cars, ie the starter and clutch fork change sides I’ll see if I can find a pic of the clutch pedal, the one in the car isn’t conducive to good photography with ‘head under the dash’ angle!
May 23, 2020 14:53:56 GMT
From a Granada manual, but sierras are the same The cable end is a loop which fits through the pin, secured by the spring clips Designed by the devil himself! Give me a mk4 cortina with 2 x 17mm nuts for adjusting any day
scimjim
@scimjim
May 23, 2020 16:09:15 GMT
The cable end is a loop which fits through the pin, secured by the spring clips So like my pic above then? Just need length and I can measure my RHD and enquire about LHD cables.
scimjim
@scimjim
May 23, 2020 16:10:18 GMT
The bellhousing on the sierras is the other way round on the LHD to RHD cars, ie the starter and clutch fork change sides I’m aware of that but I’m not talking about Sierras 😀
May 23, 2020 16:25:42 GMT
The bellhousing on the sierras is the other way round on the LHD to RHD cars, ie the starter and clutch fork change sides I’m aware of that but I’m not talking about Sierras 😀 Yes, but I am 😀 Probably won’t get a measurement tonight, but I’ll try tomorrow
Phil H
Club RR Member Number: 133
Obscure clutch cable question Phil H
@philhoward
Club Retro Rides Member 133
The protruding inner cable on a Ford “self adjusting” cable is a lot longer from memory than the Small Sports one.
We’re waiting for the bellhousing to arrive, then bolt the whole lot into the car, and I’ll get an accurate measurement then, there’s not much point until I know exactly what it needs
