time
May 26, 2020 17:35:09 GMT
Has anyone used hydraulic compression fittings on a hard fuel line ?
I have an 8mm O/D steel fuel pipe which I intend to use an 8L male compression fitting (nut and olive ) with a 3/8 Hose tail which will then have a double braided PTFE swaged hose on it to my tank mounted fuel regulator/pump this end will also be a swaged fitting
Hose and fittings are more than adequate pressure wise Just wondered what everyone’s thoughts were on this
May 26, 2020 18:50:01 GMT
I do that all the time when doing engine conversions, never had a problem. I repair Merc SLS lines with them to.
Phil H
Club RR Member Number: 133
May 26, 2020 19:51:31 GMT
Might be a bit overkill but won’t do any harm. More than adequate and if using PTFE flexibles you’ll be fine. If using normal rubber hydraulic hose on fuel lines I’d be wary - check the hose spec. PTFE is chemically inert so fine.
time
May 26, 2020 20:33:49 GMT
I do that all the time when doing engine conversions, never had a problem. I repair Merc SLS lines with them to. Aces, thanks for your advice I was quite relieved when I found it was 8mm o/d steel pipe as I have metric compression fittings on the shelf at work, il make the hose etc up tomorrow, not looking forward to dropping the tank though it’s 3/4 full
May 26, 2020 20:34:57 GMT
I use compression fittings but dislike having the end of the tube "dangling". I make fuel blocks which can be bolted down, no risk of movement then . looks better too imo.
time
May 26, 2020 20:43:35 GMT
Might be a bit overkill but won’t do any harm. More than adequate and if using PTFE flexibles you’ll be fine. If using normal rubber hydraulic hose on fuel lines I’d be wary - check the hose spec. PTFE is chemically inert so fine. Thanks for the advice, oh yeah it’s belt and braces with a ratchet strap around your waist haha I’m using the hyd fittings etc as it’s what I work with so it’s readily available
