This is a Rev2 1992 MR2 Turbo (import)
This car has a toms style body kit. Unfortunately I managed to chip one of the corners of the front bumper, but it still looks okay.
The car also has some historic front end damage. NOT ON REGISTER FOR RIGHT OFF. Better to be honest and up front! Anyone is welcome to do a HPi.
We have installed a new passenger chassis leg, new crash bar, new bumper supports. All pictures we can show and happy to answer any other questions regarding this.
Almost mint condition interior. There is a little bit of wear on the drivers seat bolster as to be expected on a car of this age, and a plastic panel behind the driver's seat is loose (just needs some new plastic clips).
Air conditioning deleted but who needs it with the T-Top roof!
Power steering deleted also.
The car has a plethora of additional upgrades which i’ll list below:
CT20b turbo from a rev3/4/5
Apexi Air filter
Walboro 255 fuel pump from TCB parts.
Upgraded aluminium intercooler.
RARE JDM Sheep and Dog exhaust Jasma Single exit and an MR2 Ben Decat.
EBC slotted disc brakes all around.
Ebc black-stuff all around.
Hell braided brake lines all around.
Polyurethane bushings with powerflex bushes, wishbones and suspension.
Six months ago the transmission was completely stripped down and rebuilt, and it had a new clutch. It also has brand new tyres all round, which are really grippy in the wet (good for current UK climate). The speedo currently doesn’t work, but this is due to speed sensor.
This is a fairly good example of an MR2 of its year, regardless of the few faults that exist. I’m looking for in the region of £5550 and recommend viewing before buying. Any reasonable offer accepted.
Some cosmetic marks of course. There is no rust other than a little on the bottoms of the doors which is common on these cars. It's hard to notice. There is cracking on the side skirts.
Some additional history:
Cambelt/water pump changed on May 2016
Hoses from hell replaced 2016
New thermostat 2016
New rocker cover gasket 2017.
Rev3 rocker cover gasket Bolts 2017
New O2 sensor 2016
Iridium spark plugs NGK 2020
OEM exedy clutch changed 2019
Tie rods and ball joints changed on 2016
Front callipers rebuild and painted black 2016
Right rear caliper replaced 2019
Handbrake cables replaced.2016
New Alternator replaced 2017
New battery 2020
Apexi Air filter
New thermostat 2016
New O2 sensor 2016
New battery 2020
