ems1
Club RR Member Number: 5
1985 Opel Manta 16vems1
@ems1
Club Retro Rides Member 5
May 28, 2020 20:47:25 GMT
Some pictures and details of my Manta. ExternalRallytech 400 road kit (i240 kit) Rallytech 400 bonnet with locking aero catches Fibreglass nosecone Early 400 light units with H4 outers and KC Daylighter inners Non-opening rear quarter windows Solid roof conversion Manta Exclusive rear spoiler, bumper and infill panel Revolution RFX alloys, 7x15 front and 9x15 rear InteriorStandard GT/E daytona check interior Momo Steering Wheel Switch panel in centre console Steering and suspensionSuperflex bushes throughout Bilstein dampers Gravel spec springs (+1") Quick rack Corsa B epas BrakesWilwood Midilite front calipers & vented discs Mk4 Astra rear calipers and solid discs Mk2 Polo Servo Golf GTI 16v master cylinder EngineEarly C20XE with Coscast head Everything is standard apart from: ARP bolts fitted to flywheel and bearing caps Magnecor KV85 leads Irmscher power cap K&N cone filter Ashley 4 branch manifold and exhaust GearboxStandard Manta 1.8 gearbox with a quick shift kit AxleManta axle with ZF LSD Steel Torque tube
Last Edit: May 28, 2020 20:49:48 GMT by ems1
1985 Manta GT/E 16v 2001 VW T4 Caravelle
ems1
@ems1
Picture of the shell when I got it in June 2013, it had been restored and re-sprayed seven years prior to purchase but not re-built. The Transit was filled with nearly everything else to build the car. I rented space in a garage for the build and finally got it on the road in December 2015. This is the only picture I've got from then as all the others have disappeared. The axle and engine were rebuilt during this time, I wish I'd done the gearbox as the input shaft bearing is now noisy. The car is used all year round, but it's only done around 4000 miles since the re-build. I don't know if I'll ever finish it, the drivers seat needs to be repaired, I need to sort out the light covers and get some spot lamp brackets made. I also have a roll cage and sump guard sitting in the shed waiting to be fitted. The car could do with another re-spray as the paint is bubbling in some places and the paint has cracked where the rear arches bond to the shell.
Oct 25, 2020 19:20:02 GMT
Very nice car. I have a 73 Manta A & I've just bought a red top. Was there a lot of modification needed to meke the engine fit?
ems1
@ems1
Oct 26, 2020 21:02:08 GMT
Very nice car. I have a 73 Manta A & I've just bought a red top. Was there a lot of modification needed to meke the engine fit? On my GT/E I used a Manta 1.8 sump, engine mounts and gearbox. I also removed a bit of the lip on the bulkhead to give more clearance for the coolant pipe. I don't know what needs to be done to an A series, there will be more information on the Manta Club forum.
ems1
@ems1
Oct 26, 2020 21:03:41 GMT
Thank you, it doesn't look as good when you're close to it!
Sweet... Always liked these. Can't remember when I saw another one? You should definitely finish it as you will have something very rare.
Jan 24, 2021 23:46:16 GMT
Lovely car i love the Mantas..
ems1
@ems1
Jan 25, 2021 18:01:51 GMT
Thanks, this one definitely looks better from a distance. It had some paint bubbles before but over the last couple of weeks they've multiplied. I'll have to start saving for a re-spray.
Jan 25, 2021 19:00:21 GMT
That is lovely - well done you. Must be a rare bird these days? I can’t temember the last time I saw one which makes it even better!
ems1
@ems1
Jan 25, 2021 19:30:32 GMT
Not that rare these where I live, as another three have turned up in the last year.
ems1
@ems1
Jul 12, 2021 18:56:22 GMT
The Manta's now been reviewed by Hub Nut on his You Tube channel.
Jul 12, 2021 19:26:57 GMT
The Manta's now been reviewed by Hub Nut on his You Tube channel. Watched that yesterday, an impressive machine you've built there. I'm jealous.
ems1
@ems1
Jul 14, 2021 18:08:53 GMT
[/quote]Watched that yesterday, an impressive machine you've built there. I'm jealous. [/quote]
Nothing to be jealous about, it looks better on TV than close up.
