I know, I know blasphemy but I need a new down pipe now because the front is just a tad too low for the speed bumps around where I live. It does have a little forward rake at the moment and I think leveling it off should be enough.
I have seen some people use spring pads for the top of the spring to raise the body up a bit, so my questions are
1) How do I pick the right pad?
2) How do I measure the height that I want and then equate that to pad thickness, is it as simple as I want 10mm extra so a 10mm pad?
3) Is this even advisable?
Thanks
Thanks
