jamesd1972
Club RR Member Number: 40
Jun 15, 2020 17:46:47 GMT
Anybody with series Land Rover Gearbox experience able to give their thoughts on whether to ignore or replace this layshaft. Thinking sowen & glenanderson . Reverse gear has taken a beating from the matching gear which has badly damaged / missing teeth. Oddly enough the reverse detent springs are also broken..... Car will be used for local / field use not as a daily. Thanks for your thoughts James
Last Edit: Jun 15, 2020 17:49:58 GMT by jamesd1972
jamesd1972
Jun 15, 2020 17:47:34 GMT
Oh and asking for a friend - ours is fine and running ! James
Last Edit: Jun 15, 2020 17:48:30 GMT by jamesd1972
glenanderson
Club RR Member Number: 64
Ouch. That’s the result of ham-fistedness. Someone’s been in the habit of slinging it into reverse either while it’s still rolling forward, or wth the revs high prior to dipping the clutch, so the layshaft was still spinning as they tried to get the gears in mesh.
It sort of depends what else he’s doing while he’s in the box, and how he’s going to treat it once it’s done.
If he’s got a good/useable replacement reverse gear and detent springs, is planning on reusing all the existing bearings and other serviceable parts, and is just throwing it back together with a new set of gaskets and seals, then it’d be fine. Noisy, and a potential future problem, but fine in the short/medium term. Driven with sympathy it would probably last a very long time; you don’t go that quick, or for very long, in reverse after all. If you know reverse is a little weak, then you’re not going to be putting it under any unnecessary strain either.
If, however, he’s putting in new gears and bearings and spending proper money on other bits, then I’d say it would be a false economy not to replace this too.
From what you describe though, it sounds like a bit of a “patch it up for minimal money” job, and that he’d be happy with a gearbox good for a few thousand miles of sensible use, rather than spending a load of cash doing a proper rebuild on something that’s seldom going to see much use. In which case, yes, reuse it.
jamesd1972
Thanks glenanderson that mirrors my thoughts. I’ll let him know- any spares would need to be bought but a couple of hundred quid is cheap when you are stuck at the side of the road looking at spending a few days ripping it all apart again ! Will report back outcome. James
sowen
Club RR Member Number: 24
Jun 16, 2020 16:34:43 GMT
I once many years back threw an early crash gearbox together, 1st and reverse were worse than that. Bought a new late series 2a layshaft, some new bearings and shoved a spare series 3 bellhousing on it and put it behind a V8. Never double de-clutched, bashed every gear and used all the throttle and revs the V8 had! Worked fine, just howled a bit
