Jun 24, 2020 11:46:18 GMT
Might as well do a thread on my '28. I started on it some time ago ( one of the first cars I did for myself after I moved to the States. At first I was going to build a ultra low chopped & channeled 2dr sedan ( before that style got popular ), but then I had the chance to buy a bare / incomplete sportscoupe body. These were cloth top coupe's , fixed roof, didnt open. With regular Coupe doors with wind up windows. But I saw some Roadster potential. I then found a Roadster cowl, and I mated that to the Sportscoupe rear. ( nothing lined up of course, but that was OK... ) This was my collection of Model A parts, sitting next to our rented mobile home.
Jun 24, 2020 12:01:17 GMT
Some time later I had a garage to work in, and thats when I got to make a lot more progress. Nice thing about a Sports Coupe rear is that the cockpit area is 8" longer, so I can recline more and sit lower in the car. A first I was going to channel it over a Model A frame with some big Z's in it, but that took up too much interior space. So I started over with a '32 frame, Highboy style ( meaning body sitting on top of the frame, not channeled ) Still not enough space for what I was trying to do... I wanted the car to be less than 4' total height, with reasonable rideheight ( 6" or so ), and enough space inside for me to take it on long drives ( I'm 6'2" ) So to accomplish that, I thought it was a good idea to not put any of the usual crossmembers in ( just the fron and rear ones that the springs bolt to). That way I could sit inbetween the frame rail and the tranny tunnel. To put strength back in I welded the floor ( which is flush with the underside of the rails ) the tunnel, and both firewalls ( bulkheads ) together as a unibody structure. Or Monocoque , as I knew it... Others have named it the Unibody Roadster, but the name stuck...
Jun 24, 2020 12:07:39 GMT
I ran it with a Supercharged early SBC out of a '57 Vette for a while, but I had trouble with it running reliably on today's pump gas. Final straw was getting stranded on my way to a friends funeral. So I let go of my self imposed rule of " no parts newer than 1960" , and stuck in a 350 SBC ( pretty mild, just a cam, some decent heads, intake and 4BBL Holley )
Jun 24, 2020 12:09:55 GMT
Jun 24, 2020 12:13:59 GMT
Jun 24, 2020 12:17:22 GMT
Its pretty much done now. Although I keep making small improvements. I made this steering wheel.
Jun 24, 2020 12:19:56 GMT
Jun 24, 2020 12:22:36 GMT
At some point, I'll pull it apart for paint & upholstery ( I always planned to do that ), but that is not a priority right now...
v8ian
Jun 24, 2020 12:23:26 GMT
That, Sir, is superb, thinking outside the box with the floor.....
Jun 24, 2020 12:25:10 GMT
Thanks man
Jun 24, 2020 13:45:43 GMT
What an awesome car You don't happen to have been making it around 2015/16 were you? I remember a Ford hotrod post somewhere on an American forum inspiring me to have a go at welding my Spitfire's bodyshell to its chassis. Can't find the forum post, mind...
1928 Ford Unibody Roadster.stealthstylz
@stealthstylz
Club Retro Rides Member 174
Jun 24, 2020 14:08:57 GMT
I love this, it looks "fast" compared to a stock bodied A roadster hot rod. We did similar to a mates A pickup a few years ago, but as it was a GRP body I built a Westfield style cockpit frame out of 25mm box section then welded the stock front and rear sections on. Worked really well for interior room.
Jun 24, 2020 15:14:33 GMT
Found it!It was you! Post number 35. You're to blame for that particular piece of scope creep for my Spitfire project. Thought I recognised the car. Thanks btw
Jun 24, 2020 20:39:50 GMT
Thanks guys. biturbo228 , I've been following your very cool Spitfire thread. And when you wrote "After much stripping and painting of the body and chassis, I thought to myself 'I've added all this stiffness to the body and plan on using solid mounts to the body...why not just weld it together and make a proper monocoque?'. Why not indeed? I don't think anyone's done that to a Spitfire before, and the only people I can find who have done it are a couple of guys on an old hot rod forum singing its praises with Model A Fords." , I thought it that looked familiar. That something I've done could be useful to somebody else is awesome. I bet it will pay off on your Spitfire like it has on my Roadster. I've driven other Hot Rods, and Hot Rod owning friends of mine have driven my Roadster. It doesn't drive & handle like regular Hot Rod. There is no scuttle shake, and because the chassis/body structure is so rigid, the suspension works much better. You can slide it in a neat 4 wheel drift, or toss it sideways for a lurid powerslide. And even change your mind mid corner and go from one to the other, or back ( havent owned a lot of cars that can do that ) But good Koni's, carefully chosen rollcenters, and skinny bias ply tires ( early brakeaway, but very predictable in a slide ), are part of that as well...
Jun 26, 2020 16:52:11 GMT
Looks pretty hot!
Jun 26, 2020 20:13:29 GMT
Thanks guys.
Kron
Jun 27, 2020 12:46:24 GMT
At some point, I'll pull it apart for paint & upholstery ( I always planned to do that ), but that is not a priority right now... I would be very tempted to leave the outside as it is. Looks very cool and purposeful, not like a show queen.
Jun 29, 2020 15:22:54 GMT
Yeah definitely inspired me to give it a go! sounds like it's really piad dividends on your hot rod so hoping it will for my Spit too. They're not known for having the most rigid of chassis
Jun 29, 2020 20:22:14 GMT
absolutely love the stance and proportions... i think it would be a real shame to paint it too.
