Whats the deal with the Daphine in front of the axle? Was in a garage for 30 years , I gave it to a friend who didn't have a project , so he would have something to build , was going on a bug pan , then he sold it the other day and kept all the money
Last Edit: Mar 21, 2021 8:36:26 GMT by atomman
Play'in round with an old Datsun & a Ford COE
got some roof marker lights, look a bit big but will be ok for now, finished cleaning up the axle ready to weld on all the 4 link stuff lots of measuring and a bit of tacking maybe need to drop the front mount a bit , need to water jet some top arm & bag brackets and make top arms next week, then double check everything first
Mar 21, 2021 18:29:14 GMT
other lower side done today
Mar 21, 2021 23:44:59 GMT
Mar 24, 2021 19:59:37 GMT
been cracking on made some threaded inserts for the rose joints and some brackets to go on the box section to chassis to triangulate it a bit nearly all mocked up now for lengths etc sorted a bed for now to
Mar 26, 2021 19:44:12 GMT
borrowed the pipe notcher from work to finish off mocking up the rear if your gonna make a bracket make it RaD one all tacked up and tested , all moves freely up and down , next to sort out he anti roll bar mounts and air bags
Mar 27, 2021 19:31:00 GMT
Measured everything again today and tweaked some bits and tacked it all up again , It all goes up and down as it should, just need to sort out the bag mounts now and the antiroll bar mounting
got some work done on the rear bag mounts bit of CAD to plan it all out , bit of water jet cutting I drilled all the rivets out holding the original cross member in , and welded in some 10mm plate to reinforce it for the middles 4 link mounts , I have now tacked in the mounts and will take it back out and finish weld it then put it back on , so i don't have to weld it all upside down , both sides now in and some box section for the upper mount that needs some finishing touches , just ordered a T-piece so i can put both bags up'n'down to test the rear movement , So not long and should be able to see if it all works , then just to take it all off and finish weld it all and give it a coat of paint , then the front lol . the list is getting shorter though
Frankenhealey
Club RR Member Number: 15
1954 Ford C-600 COE truckFrankenhealey
@frankenhealey
Club Retro Rides Member 15
Love those bag mounts
v8ian
Been watching this from the start, I'm curious as to how you are going to plumb the bags, I ask because I have been asked to look at my mates bagged van, which has developed a lean when up at pressure
Looking great.
Progress is constant.
Last Edit: Apr 9, 2021 19:38:28 GMT by grizz
Been watching this from the start, I'm curious as to how you are going to plumb the bags, I ask because I have been asked to look at my mates bagged van, which has developed a lean when up at pressure Bags are gonna be plumbed in each with there own feed and pressure sensor and hopefully level sensor to keep it all level, running along inside the chassis rails out of the way, that's the plan anyways lol . I already have the tank but unsure whether to use a converted aircon pump or twin 12v air ride compressors, hope that helps
all mocked up apart from the shock mounts , and it goes up and down !!
I did have a beer to celebrate...
v8ian
Thanks for the pics, I have my ideas on how to rectify the problem, I may do away with the spool valves, as I believe one is lazy, and not giving enough flow to pump up the "lazy"bag before the pressure switch shuts the system down, I think the valves will be swapped out for very basic solenoid valves, 2 for up, controlled by a pressure switch, and 2 for down dumping via silencers
Apr 28, 2021 19:47:02 GMT
Been welding up the rear and changed out the test brackets for some nice 6mm ones with a few more holes for some adjustability , and strengthened up the cross member with some 10mm plate , still got some more gussets to put in to Now time for the front, I did mock up a top arm last year , so worked out some brackets and tacked them on to get some extra measurements and stuff, Arm is to long for now, so needs a bit of shortening, say 25mm out , easy as its only tacked together , wheels already have a nice tuck and don't seem to catch the chassis or the wing with room for a but more drop to , may be able to use the Iveco bottom arm but need to check the length when the top is the right , still need to work out top shock mount and bag etc etc , cant wait till the front goes up n down to
Every update makesme smile.
Looking good mate.
jamesd1972
Club RR Member Number: 40
1954 Ford C-600 COE truckjamesd1972
@jamesd1972
Club Retro Rides Member 40
Like the progress and the proper engineering going into this. Going to be awesome, can't wait to see it see it low front high back to see how much rake you can get with a bed on to emphasize it. Have a sneaky feeling it would rock the gasser look too ! One question will the temp bed clear the back wheels at low ? James
Apr 29, 2021 12:47:30 GMT
Like the progress and the proper engineering going into this. Going to be awesome, can't wait to see it see it low front high back to see how much rake you can get with a bed on to emphasize it. Have a sneaky feeling it would rock the gasser look too ! One question will the temp bed clear the back wheels at low ? James thanks for the kind words dudes, Want to try and make some arches for the back , I could mount them to the axle so they don't move or the bed so when it's slammed it will tuck nice but will have more clearance when the bags are pumped up, saw some cool pics that a bloke had made some the other day , will try and find them , here's a ruff sketch i did the other day for the bed . this has pick up rear arches on though
Had a bit of luck on my side this week and found this Was gonna break it and put the back on the CoE but it's far to RaD & 70's shagpile'd. gotta sell my T4 camper though to pay for it now
