60six
Jul 17, 2020 10:55:23 GMT
Hi recently bought an engine (B204 saab) which I thought was OK - turned over fine, fitted fine, ran for over an hour in the garage fine. Took it out for a spin and it started to tighten up and make odd noises after 15 mins - next thing I know is BANG and the lump is gone. Pulled the head off - head absolutely fine. not warped at all. appears to of been starved of oil in the cylinders. Not knowing how oil gets to the cylinders what should I be looking for as to the cause? plenty of oil. it didnt overheat. Needless to say that the bottom end cannot be rebuilt! Another engine on the way.
Jul 17, 2020 11:38:20 GMT
Check the state of the oil pump and the strainer in the sump. You can see it's full of sludge in your picture.
One of the Saab engines is notorious for the strainer clogging leading to oil starvation. I would pull the sump and give everything a good clean out on your next engine before fitting.
Last Edit: Jul 17, 2020 11:40:01 GMT by dodgerover
60six
Jul 17, 2020 13:32:45 GMT
curse word - That would of been really easy to do as well! Live and learn!
60six
Jul 18, 2020 13:43:02 GMT
I did know that, and had recommended others to do that too.
People do the oddest things!
taking the engine apart was painful - It was so clean and the cam showed no signs of use....
Jul 18, 2020 19:12:57 GMT
Good effort dude ,the bent rod needs to be mounted on wood on top of fireplace 🚗🚙😎👌
60six
Jul 18, 2020 23:46:25 GMT
Just thinking that would be an awesome award for engine management!
I am going to award myself this 'Dunce' trophy to myself for putting in an exceptional amount of work on a 500 quid car, 6 months of evenings and weekends doing everything nicely only to blow it to bits on my first test run.
I remember vividly whilst polishing the alloy rocker cover to shiny aluminium "this engine is not going to be good - when has anything in the engine bay been tarted up in a really time consuming way EVER been a good luck charm for me and cars in general? "
Never! - I once spent too much on a chrome plated coil on a VW beetle. Damn thing was a micron smaller than the original so one day it slipped out of it's bracket, caught the main pulley and absolutely anhililated the engine bay. There were dents on the outside of the decklid from the force of the 'Pinball machine effect' - I really hope I have learned something this time.
HA!
Jul 19, 2020 21:12:46 GMT
Check the state of the oil pump and the strainer in the sump. You can see it's full of sludge in your picture. One of the Saab engines is notorious for the strainer clogging leading to oil starvation. I would pull the sump and give everything a good clean out on your next engine before fitting. That's the B2*5 that has problems with the PCV pipes breaking down leaving lumps of rubber in the oil to block the strainer. The B2*4 generally doesn't have any such problems, but as with any engine if it's been abused and had a complete lack of maintenance it will suffer, especially if it was also tuned and/or misused as the turbo will cook the oil. This B204 is definitely an anomaly but not the first I've come across that's had issues like this after being bought 'unknown'. I've not seen a B2*4 with a sump that mucky before. That rod is a thing of beauty though
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
Jul 19, 2020 22:34:22 GMT
Yes, a worthy addition to a black museum.
Yes, a worthy addition to a black museum. Careful there Mate, the misinformed and misguided might start marching 🤣🤣🤣
Jul 20, 2020 14:38:07 GMT
The strange thing is the crank journal does not look like it has seized, on the con rod one bolt is shown as clearly sheared, is the remains of the other broken of as well or has it come unscrewed?
I was once doing Power runs on cosworth YBG on a very expensive 4wd dyno also used for emissions development we were looking for the cause of a strange ticking noise with microphones on the engine, under full load around 6000rpm it went from tick to a knock then an almighty bang in 2 or 3 seconds, conrod and piston had virtually cut the the sump and crankcase in half filling the dyno and with a mixture mobil 1 and YBG fragments, it cost over 10 grand to clean the dyno!
root cause was a conrod bolt coming undone.
Jul 20, 2020 14:59:05 GMT
I think i've said before but I saw a Bedford straight six diesel throw a rod after the owner had screwed out the governor. Its quite impressive when the engine is about 8 litre capacity and the rods the size of your lower leg. Apparently the early RR Griffon engine fitted in the Mk12 Spitfire did a similar trick and they were 37 litre engine. So all in all , good job sir you're in excellent company.
Jul 20, 2020 18:41:28 GMT
Is the knackered piston seized in the bore? It's a odd one that, it looks more like hydraulic lock damage than a crank oiling failure but from the photos you've posted the cylinder looks dry.
drseg
Jul 20, 2020 23:36:41 GMT
agree the rod looks hydrauliced rather than anything else
Was this run without water?
I've had a seized piston in one car before, a 944 S2.
The root cause was seen to be severe overheating, which tied in with the ropey cooling system it had.
Jul 21, 2020 10:01:12 GMT
The bore would be heavily scored up and the piston will be seized in there if that is what came to a stop, from the pic of the bore at that angle that doesnt look the case, but you wont know until you try and remove it. As it has mullered itself it is difficult to say what happened when, but tightening of the engine is a good sign it is seizing in the bores although not always. The piston has rotated in the bore in its final moments at any rate.
Your head cant be much good on that piston with all that metal flying about can it? Unless the piston stopped there. Any smoke while this was all happening? Fuel wash from duff injector maybe?
Last Edit: Jul 21, 2020 10:08:15 GMT by sausage
