Jul 18, 2020 19:46:17 GMT
Is anyone on here familiar with the Granada 2.0 dohc cam followers? Following the strip down of the engine in my Pop build thread I have a possible issue. Out of the eight, three are solid, I can't move them at all. The rest can all be compressed. Given the state of the oil I'm wondering if they are solid with congealed crud. Any thoughts because I have no idea what is correct.
Hydraulic cam followersstealthstylz
@stealthstylz
Club Retro Rides Member 174
Jul 18, 2020 20:26:44 GMT
Try cobbling something up to squash them in a vice. Looking at the state of the oil in your build thread though they'll at least need to be stripped and cleaned. IIRC they're of a common type though, I can find out Monday but I'm sure replacements are about 4 quid each or something.
Jul 18, 2020 22:18:22 GMT
Thanks. There's no way to strip these. I'll give them a go in the vice and see what happens. I guess it's replacement time if the resist🧐
@stealthstylz
Find out if there's a local engine shop that has a stripping tool for hydraulic bucket followers. It pumps oil in to blow the centre out then you can strip and clean the moving bits.
in my experience of peugeot tappets the squishy ones are the problem not the firm ones, unless the firm ones are fully compressed and stuck.
Thanks to Stealthstylz! His comments prompted me to have a look for information on dismantling these and I found a couple of very informative videos which detail how to service these. All set now.
vitesseefi
South West
in my experience of peugeot tappets the squishy ones are the problem not the firm ones, unless the firm ones are fully compressed and stuck. True on VAG ones as well Nick
@stealthstylz
Jul 19, 2020 13:17:04 GMT
It depends on how long the engine has sat generally. If it's been run recently they should be solid, over time they can drain down though. Should always squash them out before refitting ideally as it gives the cam a easier time turning before the oil pressure has built up.
Jul 19, 2020 15:09:48 GMT
Last run about 12 years ago. I'm starting to get them apart now. I had to soak them in solvent to get them free, the gunk inside was near solid. Unfortunately banging them down on a wooden surface has given me grief as I have arthritis in my RH index finger. I have to make das tappetsmackensplittenstick. Thanks again to Stealthstylz for pointing me in the right direction.
Jul 19, 2020 16:22:15 GMT
All apart🙂
