Jul 22, 2020 20:48:46 GMT
Can the good people of RR help me out please ? I'm in need of suspension ideas i've now got a old Ford COE and plan (need) to put it on air bags to put it on the floor when parked and for ride quality etc , been looking at 4 link set ups,leaf and bag and various ways to achieve this, Can we have a nice thread filled with suspension mods and slammed trucks ? maybe some good and bad ideas ? Thanks all here's a start
Last Edit: Sept 3, 2020 18:06:07 GMT by atomman
Play'in round with an old Datsun & a Ford COE
Jul 22, 2020 20:50:43 GMT
Jul 23, 2020 19:44:28 GMT
Jul 23, 2020 19:54:00 GMT
I have much to add to this thread. Which I shall hopefully be able to tomorrow.
Jul 23, 2020 20:19:36 GMT
The actual suspension stuff is just ‘conventional’ stuff sized up. It’s not hard and truck sized bags are cheap.
The issue you will have is supplying enough air reliably. You need to be running a high pressure engine driven setup with a big tank and valves. I’d say 1/2” valves, 8gal tank At 200psi minimum.
I can detail the specifics but you need a good background knowledge first so do some reading if you haven’t already.
The actual suspension stuff is just ‘conventional’ stuff sized up. It’s not hard and truck sized bags are cheap. The issue you will have is supplying enough air reliably. You need to be running a high pressure engine driven setup with a big tank and valves. I’d say 1/2” valves, 8gal tank At 200psi minimum. I can detail the specifics but you need a good background knowledge first so do some reading if you haven’t already. Thanks Dez , I've done a bit before, any specifics would be a great help,
Jul 24, 2020 15:32:51 GMT
Last Edit: Jul 24, 2020 15:33:42 GMT by HoTWire
Jul 24, 2020 15:36:04 GMT
I'm aware they are mainly pickups... but they are US pickups which are basically the same size
Jul 25, 2020 13:57:21 GMT
Jul 25, 2020 16:20:16 GMT
I assume this is on air, but its the only answer ive got.
Jul 26, 2020 16:29:55 GMT
I really like those foot well windows
Its not finnished, but I think this belongs here
Potential Retro Rides merch vending van? Please?
Aug 12, 2020 20:37:50 GMT
Aug 15, 2020 16:44:56 GMT
