Rare Obsolete kit
1/10 R/C Alfa Romeo 155 V6 TI Martini (TT-02)
Item No: 58606
Shell, wheels and tyres never used, Chassis only used a few times. Comes with LED light set.
This R/C model assembly kit recreates the racy Martini sponsored Alfa Romeo 155 V6 TI, which featured a purpose-developed 450hp-plus 2.5-liter V6 engine mounted in the front, and paired with a 6-speed semi-automatic transmission. A hi-tech flavor was added by electronically controlled front, central and rear diffs, traction control and ABS. It remained in contention for the prestigious 1996 International Touring Car title until the final race. The model artfully captures the form of the car, with large front bumper spoiler and bulging front/rear fenders. Stickers are included in the kit to recreate the unmistakable livery of the car.
Specifications
●Length: 462mm, Width: 185mm, Height: 138mm ●Wheelbase: 257mm ●Tire Width/Diameter: 27/67mm (Front & Rear) ●Bathtub-type Frame ●Shaft-Driven 4WD ●Front/Rear 4-Bevel Resin Differentials ●3-Piece Steering Tie-Rod ●4-Wheel Double Wishbone Suspension ●Front/Rear Friction Dampers ●Gear Ratio = 8.27:1 (9 further ratios from 11.38:1 to 7.28:1 possible with use of separately-sold pinions)
Item No: 58606
Specifications
