Lada Riva rolling shell, shell was stripped down for bodywork, had new wings, front end, chassis legs, jacking points welded in and needs putting back together.
Engine is in the bay on the mounts but gearbox and prop aren't fitted but are there for it, front seats are unbolted and ancillaries, wiring and fusebox are stored inside the car and boot.
V5 is with it, great project either to fit a different engine or use the rhd bits to convert an import etc.
Located in cowdenbeath, it rolls easily enough so loading onto a trailer shouldn't be much issue.
