617sqn
Club RR Member Number: 176
IP address blocked617sqn
@617sqn
Club Retro Rides Member 176
Aug 20, 2020 17:16:16 GMT
Hi all. I need some IT assistance please. On one of my other car club forums, i can read all of the threads but whenever i try to reply to a post, it gets blocked. Is this likely to be a fault with their site or will it cover all others ?
Andy G
Aug 20, 2020 18:10:42 GMT
if you are doing this at home, switch off your router then back on, sometimes this changes your ip address
then try again
if it don't work, contact the forum admin and give them your ip number to unblock it
for your ip number just google "what is my ip", and it will show
ballbagbagins
Club RR Member Number: 164
IP address blockedballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Aug 20, 2020 19:27:17 GMT
If you issue the command ipconfig/renew in a dos prompt you'll get a new ip
cjj
Aug 20, 2020 21:09:10 GMT
If you issue the command ipconfig/renew in a dos prompt you'll get a new ip On the local network (e.g. between the router and the device). Won't make a jot of difference to the public IP (e.g. between the router and the ISP). Happy to be disproven, but I'm pretty sure on this.
ballbagbagins
@ballbagbagins
Aug 20, 2020 21:16:01 GMT
Sorry, I'd made the assumption that it was the ip of the op which was being blocked by the car site.
You're correct, that command would only change the ip of the op.
