logicaluk
Oct 17, 2020 16:43:37 GMT
I just had a rush of blood to the head and bought a Kemppi Minarcmig Evo200. I can honestly say I’ve never used a better welder. That’s a serious rush... Kempii are excellent. OMG as the Young ones say, I'm surprised you can still stand up, what with there being no blood left anywhere in your body. Have you been working 29 hours a day overtime? Seriously though they are supposed to be very Good machines, I had a go with an old one a while a go in a mates shop with Good results. Unfortunately well out of my pocket. Dan
Last Edit: Oct 17, 2020 16:45:00 GMT by logicaluk
glenanderson
Club RR Member Number: 64
Oct 17, 2020 17:31:44 GMT
I am still struggling back to my feet, yes, but my last welder bought new was a Sealey Supermig 185 in 1995, and if the Kemppi lasts as well it’ll be cheap in the long run.
Oct 18, 2020 19:30:41 GMT
One thing my workshop is missing is the capability to stick bits of metal together, I used to have the long term loan of an old Clarke set but that had to go back home. After a not inconsiderable amount of research the best MIG set for the money has to be the 180A RTec. At the best part of £500 inc www.r-techwelding.co.uk/mig-welder-r-tech-i-mig180/In steps the new contender, 200A Blackline from Rally Designs. Cheap looking torch and lead, only takes 5kg rolls of wire. But at £230 + a regulator, its very tempting. www.rallydesign.co.uk/product_info.php?products_id=22932Ahhhhh choices.... any opinions or suggestions? Dan I too had loaners. And cr*p ones. And "supposidly" good ones. Bought an R-Tech. What can I say. I thought I could weld until tried it and it makes this hack look good. SO much better. Fabulous bit of kit. Buy it and be happy or suffer for the lack of it. Mu tuppence worth.
logicaluk
Oct 18, 2020 19:52:03 GMT
Today I have mostly building a gearbox, but First, an addendum to yesterday's post. 20201018_121653 by logicaluk, on Flickr Here is a full GAB505 kit top and GAB507 bottom, I didn't use the last clutch plate on the bottom row, time will tell if it should have gone in. I started off building up the rear clutch pack and got the case up on the bench cleaned the bearing surfaces and started to assemble it, all went well, the parts follow a fairly logical order, with help from the BW manual's exploded diagram I made it all the way up to the front clutch pack and realized I'd missed the rear clutch brake band, no problem whip it all out ad fit it(I even managed to get it in the right way up First time, as the fit in opposite directions) Refit all the parts following the diagram there one thrust bearing I can't find a place for, take it all out again, find place for it and refit it all, get to the front pump,(which is the front face of the box) and thought hang on a minute there's a bit missing, it's rolled under a piece of cardboard, and as it was on a separate line of the exploded diagram id missed it. 20201018_140744 by logicaluk, on Flickr Take it all out again, fit missing shaft, put it all back together again. Get a NOS front pump out of stock, BAU1798. 20201018_140211 by logicaluk, on Flickr Which even comes with a new oil pick up pipe. 20201018_140249 by logicaluk, on Flickr Bolt the front pump on after a quick clean up, try to turn the gears over and the whole lots jammed solid, unbolt the front pump and take the front clutch pack back out realize I've missed a thrust bearing put it all back together again, no it won't go back together as a shim has moved in the middle of the clutch pack and it won't go on the shaft, luckily the shim moves back with a seal pick and I don't have to strip the clutch pack down, so put it all back together, and look at the break band pistons which are just need lubing and new O'rings, But I've missed the rear brake band adjusting bolt out and will it go in with the brake band in position? Will it curse word so because I missed this out 20201018_155546 by logicaluk, on Flickr I have to do this, again. 20201018_145405 by logicaluk, on Flickr Build it all up again, only to find out the head of the bolt won't sit nicely in the brake band, take it all apart and change the brake band for a different one, and rebuild the box again, luckily for the last time(fingers,toes and testicles crossed) then add the valve block and all its pipes which took some head scratching as I seemed to have an extra pipe, I did wonder if Mrs badger had played cunning trick on me, but it turned out it went on the back of the valve block. Then I hit an actual real problem that wasn't of my own making, the BW manual says there should be oil sealing rings here, which is where the governor goes. 20201018_154614 by logicaluk, on Flickr And there is none left in the rebuild kit. That is going to have to be a problem for another day. Dan
Last Edit: Oct 19, 2020 3:51:41 GMT by logicaluk
Oct 19, 2020 12:29:08 GMT
Plus 1 for the R tech. I bought one and its great.
Mention to them you are on Retro Rides and the RR deal. Think it's expired now but they still seem to honour it if you ask (about 10% if you are lucky).
logicaluk
Plus 1 for the R tech. I bought one and its great. Mention to them you are on Retro Rides and the RR deal. Think it's expired now but they still seem to honour it if you ask (about 10% if you are lucky). Didn't get the RR deal but did get a roll of wire and some tips. Very helpful, could have tried to sell me a bigger machine but didn't, it arrived yesterday but haven't unpacked it yet. Going to save that till the gearbox is back together. Dan
Last Edit: Oct 21, 2020 8:47:43 GMT by logicaluk
logicaluk
Oct 25, 2020 20:27:13 GMT
Guess what, the box had to come apart again this time it was to get the tail shaft out to find some seals, the manual seemed to show them, but they looked like the metal/hard plastic bearing type rings called oil control rings in the manual but nothing like it in the rebuild kit, I found a proper old school hydraulic engineering company, the guy running it was sat behind a kneehole desk with a huge pile of job cards on the desk, real card job cards, with a wall of different sized seals behind him, a 1950s bus sized trolley jack on the floor that had just come in for repair, I was happy I had found the right place. I showed Dave the shaft and explained what I was after and pointed to the similarly described rings on the shaft and the diagram In the manual, they are piston rings says save I don't think They do them that small, besides it's not moving you want an O ring, odd size for an O ring, says Dave with his vernier caliper in hand. Dave picks up the phone and calls a supplier and orders 6 pairs of different sized rings one of them will fit as it. I went in the next day and met his son who took one look at the pile of O rings and slipped one on the shaft bingo First try, when I proffer a £10 note he says they are 12p each I think I can let you off with that. Top chaps D&A hydraulics, 24-30 Francis St, Hull HU2 8ED. I'd got quite Good at this so the box was back together in about half an hour 20201018_172358 by logicaluk, on Flickr 20201024_120257 by logicaluk, on Flickr With that back together It's time for a workshop tidy up. Oh, I did have a quick go with the new welder I need a hammer rack. This was just a fill weld where I had cut the angle to bend it, 0.6 wire full power 20201024_143228 by logicaluk, on Flickr Happy with that, less happy with my esab auto darkening mask, the head strap had broken and I've had to use a normal mask, so all the rest of the welds looked shocking. Dan
Nice one on the O-ring. Definitely worth dropping in a packet of Choccy biscuits!
Found a place a bit similar when I was rebuilding my brake pump. The guy spun on his chair, grovelled around in two boxes, said, "120 Peso" and an O-ring and a shaft seal later, we were good to go. Two quid v anything up to US$700 for replacement.
logicaluk
It's amazing how quickly things change, this weekend I was hoping to get the gearbox and engine trial fitted together, to work out the size of the spacer behind the flex plate, but it's not Covid-19 more, my discs got lonely and decided they wanted a quick pre-lock down meetup with the local nerves, It went like this, Wednesday they had a grumble about missing each other and it looked like lock down was going happen which calmed but didn't let it go. Friday I'm thinking easy weekend may be a little light tidying In the workshop and a walk. Sat turns out I can't walk to the kitchen without having to closely inspect the carpets for a few min while I get my carp together to try again. Monday I got to inspect the lino at Hull A&E (which was very good quality) when I went to wash my hands and completely forgot I really needed them to help retain a semi upright position when on crutches and had to put my self on the floor quickly before I screamed, later after a thorough check a nice lady gave me a pill which really chilled me out, and they took me for an MRI and a neuro surgeon checked me over and said if it's not right in 4-6 weeks get a referral from the GP. Later in the day my(I say my as I don't think I've had the same one twice in a good few years) GP spent a good amount of time talking to me, adjusted my medication, so I've got an emergency painkiller, and now I have to wait. Tuesday and Wednesday I don't remember much about as the painkillers were very Good, Thursday I made it out the house and around the back garden, which is small. X2 Friday walked to workshop. Sit on chair (think about the project) walk back to house x3 Sat as above x5 So that's why now I've got to tell you about the project. I've always liked Pickups, but they are not exactly plentiful, but what I do have is most of a stalled triumph herald rebuild, the chassis was done a few years ago. I've got most of the body parts which I have been picking up for a while but I've no idea how they will be after being in storage for many years. I was going to run with a 1200 bonnet as I prefer the shape but then, the V8 fell on my lap and I had the perfect somewhere for it to go, with that, the new workshop it and then casually being offered a GRP 13\60 bonnet for the collecting, the gears aligned and I thought it's time to do it. But now I'm lying most of the day resting getting up as often as I can and having a short walk around the garden or to the workshop and back, whilst waiting for my back to get better. I need something to look forward to So it's time for some imagineering, I've been kicking this idea about for ages, herald pick up something for taking stuff to the tip or going to a show in, parts runner, it's never going to take big loads it's got a small load area, it's just for fun. It's also a rebody so all legal From Google this is the best one full for sale ad here linkThis car by Quiller triumph is probably the best roof job I've seen. I'd like to bring the rear pillar further back change and the rear window to a more conventional pick up type, but it looks like there's not much space behind the bucket seat 2 by logicaluk, on Flickr The roof also has to unbolt like a herald one. But there's not much space in the bed already (could the bed be lengthened could I do it?) 93 by logicaluk, on Flickr But then another thought occurred to me, the triumph courier. Triumph_Couriervan6266 by logicaluk, on Flickr What if there was a big brother, one with sides that came up further out, maybe at the tip of the fin and went straight up,and the rear roofline went up a bit like an Astra Max van. It would still have herald charm but be a far more useful van. Also having a slightly larger motor in it would help overcome come the wind resistance media.gettyimages.com/photos/triumph-herald-1360-estate-picture-id1175887296?s=2048x2048There you go that's what I've been thinking. What do you think? Dan
Last Edit: Nov 8, 2020 12:34:00 GMT by logicaluk
The Herald van is a great idea 👍👍
logicaluk
The Herald van is a great idea 👍👍 Standard or courier max? Dan
Well,both of them but I suppose it's easier to make the panel van instead of the "estate"
I really like the standard courier van, they, well pretty much all car derived vans look really good to me. I’ve had quite a few small vans, and like bubble vans too... but they can look a bit gawky, so think it would be harder to get the lines right (but much easier that trying to lift the whole top (like a kango or the later combo van) tbh a bit more height in the back would be really good for my work van, so would be worth the effort Shall continue to watch with interest And hope the back gets better soon
you could come up from the base of the light so the van body effectively extends rearward between the lights.
logicaluk
Thanks john, it's driving me potty.
Kevin, I don't think going any further back than the tail lights would look right and the inside of that point is fairly narrow.
A small problem and the main reason I've spent so long wandering down the pickup path, is the lack of available courier/estate roof and tubs. I've been looking and had found a very rough example for OK money, turned up to collect it, only to find the owner was on holiday and hadn't told her parents we were coming or where the keys or docs were then started upping the price, so I walked away.
Without the longer roof, I would have to fabricate the back few feet of roof panel to keep the profile which I think is beyond my skill set, but having watched GN rebuild the Jowett Bradford van, I did think that style of ally skinned wood frame would be possible, but it would have to deviate from the Herald style roof giving extra useful space.
Or what about making a truck cab losing the entire rear body and building a bespoke body on the back one that could act as sleeping quarters with a tent supplying the rest of the space. Or a micro caravan sat on the back Dan
Last Edit: Nov 9, 2020 6:31:45 GMT by logicaluk
Perhaps you might be better going back to the pick up idea and then making a hard top / camper or whatever else takes your fancy as a bolt on, for ultimate flexibility you could go for a open top pick up with a half bulkhead behind the seats like a Landrover.
The pick up above has the cab back panel all wrong for useful space, the panel should follow the profile of the seat back ie further forward at the base than the top.
The other consideration is how will it drive with the heralds swing axle a high C of G could make it all a bit scary.
Whatever your choice, hope the back gets sorted!
glenanderson
If you want to get into the local tip around here, in a van or a pickup, then you need a permit. A permit you can only get if the aforesaid van/pickup is the only vehicle in your household. I appreciate it might be less draconian in your neck of the woods, but I’d make sure before I went to the trouble of building something special that it doesn’t end up unusable.
I really like the courier/estate shape. I was “this” close to buying a rebodied Vitesse with an estate rear on it a few years ago.
logicaluk
Whatever your choice, hope the back gets sorted! Thanks George, to be honest I'm fishing for ideas, maybe some potatochops, not being able to even get the chassis on the work shop to work on the best I can do is imagineer. I might run it as a saloon till I decide what to do with it, but that means I've got to put a floor back in as most of it has disintegrated. Dan
logicaluk
Perhaps you might be better going back to the pick up idea and then making a hard top / camper or whatever else takes your fancy as a bolt on, for ultimate flexibility you could go for a open top pick up with a half bulkhead behind the seats like a Landrover. The pick up above has the cab back panel all wrong for useful space, the panel should follow the profile of the seat back ie further forward at the base than the top. The other consideration is how will it drive with the heralds swing axle a high C of G could make it all a bit scary. I like your thinking, it's followed a very similar path to mine, (except not looping back on it's self) The basic idea was just that a half bulkhead with a bolt on hard top roof, the reason I like the Quiller car was they used saloon doors with the square corner and has the B pillar coming back, and yes a totally wrong approach to the rear window. I like the idea of a camper bed body. As for the handling, It's going to have a spit 1500 swing spring and thicker ARB Dan
Last Edit: Nov 9, 2020 10:46:01 GMT by logicaluk
