jimi
Sept 26, 2020 17:37:08 GMT
So what you really are telling me, is not to use Stainless. 😉 Not at all, stainless is great, unless they need to be hi tensile or similar, I use stainless when I can. Just take minor (lubricant) precautions and you'll be fine. ........I am still talking about nuts/bolts
Last Edit: Sept 27, 2020 0:15:31 GMT by jimi
Sept 26, 2020 17:46:11 GMT
I'm pretty sure they are series 3 land rover mirrors, I've got a pair you can have assuming they are still OK, I'll try and dig them out.
Pesonally I would use steel bolts and copper ease, for both steel and stainless the main thing is to get a decent quality bolt which is properly graded.
Last Edit: Sept 26, 2020 18:19:24 GMT by kevins
Sept 26, 2020 18:18:44 GMT
jamesd1972
Club RR Member Number: 40
Sept 26, 2020 19:34:41 GMT
Last Edit: Sept 26, 2020 19:43:59 GMT by jamesd1972
Sept 26, 2020 19:42:58 GMT
On reflection I think they are Land rover mirrors 🤣
Sept 26, 2020 20:23:15 GMT
that mirror is almost certainly a stock truck part. A trip to Aghabridge will sort a replacement quickly and cheaply. Cheap enough that you'll probably buy a pair so they match properly.... I keep forgetting how good they are. But seems there were answers quickly after I posted. So what you really are telling me, is not to use Stainless. 😉 Not at all, stainless is great,unless they need to be hi tensile or similar I use stainless when I can. Just take minor (lubricant) precautions and you'll be fine. ........I am still talking about nuts/bolts I always try to future proof stuff when I work on it. So SS makes sense too. I'm pretty sure they are series 3 land rover mirrors, I've got a pair you can have assuming they are still OK, I'll try and dig them out. Pesonally I would use steel bolts and copper ease, for both steel and stainless the main thing is to get a decent quality bolt which is properly graded. Thank you. Have sent a PM re mirrors. They look to be the right ones for sure. Interesting that the left one on the Rockit is also oxidised or corroded. Looks right James. And I have posted between posts too, makes no difference. Remember this thread is also a reference document. On reflection I think they are Land rover mirrors 🤣 Yup.... Seems they are.
Sept 26, 2020 20:26:29 GMT
In the mean time, I also got this PM on UKGSER Forum Rian,
I've a L/H and R/H set of MUD blind spot mirrors that were on one of my Defenders that you're welcome to. They'll fit on standard LR Defender mirror mounts.
www.mudstuff.co.uk/products/...nd-spot-mirror
I'm not in Whitstable any more so not sure how they'll get to you.
Let me know and if you do want them, just pay it forward. David
Looking at the link, they seem to be really nice. I like the idea of the blind spot though.
Sept 27, 2020 6:36:32 GMT
Made up a small chassis number plate to add to the fibreglass body this week. I will screw it inside the glovebox in the end. The chassis number is on the chassis leg as expected, but not very well accessible. I wondered if it will be visible once the motor is back in, and it has been painted in under seal. Nice to have the right tools. Thanks Bootfair. Need to get the RX8 seats out of the C10 cab in the garage to start removing all the motors to lighten the drivers side up. Also need to find out if MX5 rails can be used on them.
logicaluk
Sept 27, 2020 7:46:11 GMT
not so much the tensile strength that annoys me with SS but the galling, I find really....... Err whats the word, um....... irritating. Sorry I should have been clearer, rather than trying to be funny. I've had a lot of problems with SS galling on my herald base kit car project a while ago, not just from being over tightened but from being run in with power tools, bolts would lock solid before they were fully seated. Now I try to use a ceramic grease when I'm using SS fasteners as well just to be on the safe side of the galvanic corrosion. Dan
Last Edit: Sept 27, 2020 7:48:03 GMT by logicaluk
glenanderson
Club RR Member Number: 64
Sept 27, 2020 8:12:26 GMT
I can let you have a spare mirror head if you’re not already sorted. You can also replace the glass easily enough, for pennies. It’s worth keeping a couple of spares in stock. I’ll show you how to get them off when I come up later this week. link
Sept 27, 2020 10:00:25 GMT
not so much the tensile strength that annoys me with SS but the galling, I find really....... Err whats the word, um....... irritating. Sorry I should have been clearer, rather than trying to be funny. I've had a lot of problems with SS galling on my herald base kit car project a while ago, not just from being over tightened but from being run in with power tools, bolts would lock solid before they were fully seated. Now I try to use a ceramic grease when I'm using SS fasteners as well just to be on the safe side of the galvanic corrosion. Dan I will do what I can to ensure it all comes together right. Fingers crossed nonetheless
Sept 27, 2020 10:02:02 GMT
I can let you have a spare mirror head if you’re not already sorted. You can also replace the glass easily enough, for pennies. It’s worth keeping a couple of spares in stock. I’ll show you how to get them off when I come up later this week. link Morning mate. Yes, looking forward to seeing you whenever you make it here. I think between kevins and me we have that one covered. But that is stupidly cheap for a glass once you know how to remove it all. The tractor is bloody nice, and tbh I am envious. Thankfully I have enough stuff to keep me busy. Is this what you mean?
Last Edit: Sept 27, 2020 10:06:29 GMT by grizz
glenanderson
Sept 27, 2020 11:50:18 GMT
Yes, that’s it. An Allen key underneath to pop the head off, then lay it in the washing up bowl and pour a kettle full of boiling water over it. The outer bead goes dead soft and just rolls off. Swap the glass and roll the seal back on. Five minute job.
Sept 27, 2020 13:36:53 GMT
I've just spent a very enjoyable few hours reading all this. You're probably expecting me to say "go for the Beetle floorpan!" but in this instance I'm not!
If it was mine, I'd see how low you can get it as is, get the engine and gearbox in and running, see how it goes and then consider more MX5 bits at a later date.
Sept 27, 2020 15:39:41 GMT
Saw this in Instagram thought of you !
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Sept 27, 2020 15:44:29 GMT
I can’t keep up! Every time I look at this thread I’m two pages behind! 😂
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
jimi
Sept 27, 2020 15:58:39 GMT
Talking about VDO gauges, came across these today, IIRC they came out of an Audi coupe that my B-I-L scrapped years ago. Any use to you?
Last Edit: Sept 27, 2020 15:59:31 GMT by jimi
Sept 27, 2020 16:36:56 GMT
Yes, that’s it. An Allen key underneath to pop the head off, then lay it in the washing up bowl and pour a kettle full of boiling water over it. The outer bead goes dead soft and just rolls off. Swap the glass and roll the seal back on. Five minute job. Amazing.
Sept 27, 2020 16:40:33 GMT
I've just spent a very enjoyable few hours reading all this. You're probably expecting me to say "go for the Beetle floorpan!" but in this instance I'm not! If it was mine, I'd see how low you can get it as is, get the engine and gearbox in and running, see how it goes and then consider more MX5 bits at a later date. Hi Neil, Thanks, that’s good to hear. I am really enjou9ng this, as it has pretty much become a team effort. Containing cost against maximising pleasure is the driving force. And your second line: ABSOLUTELY.
Sept 27, 2020 16:42:24 GMT
Saw this in Instagram thought of you ! I really like that, the artwork and the sentiment Dan. Thanks for posting. Will copy and paste into the driving thread on the general section.
Last Edit: Sept 27, 2020 16:46:24 GMT by grizz
