Iainr
Sept 15, 2020 16:00:29 GMT
My normal online imperial fixings supplier cannot supply the items I am looking for and over time have been reducing the range of stock. I wondered if anyone has any recommendations for a good online supplier who at the very least has the fixing below but also at a reasonable price.
The items I am struggling with are:
5/8 UNC nuts (un-plated) both half and full nuts
5/16"x1" UNC coach bolts
Thanks Iain
Last Edit: Sept 15, 2020 16:02:43 GMT by Iainr
Sept 15, 2020 16:04:25 GMT
awoo
Sept 15, 2020 16:11:07 GMT
+1 for namrick
melle
South West
It'll come out in the wash.
Sept 15, 2020 17:07:21 GMT
I usually buy small quantities through eBay from the likes of KayFast and BoltWorld, and large quantities directly from the same sellers.
Sept 15, 2020 17:30:19 GMT
I've used Spalding Fasteners a lot, although I usually get stuff from them at shows rather than online as it seems to be a bit less costly. Not an option for now, though. Most of their nuts are BZP, though.
Sept 15, 2020 20:07:29 GMT
Acorn fastners are great for obscure stuff. They have a huge stock of NOS fasteners.
Sept 16, 2020 5:43:56 GMT
I use sterling nut and bolt in Peterborough they stock most things at a good price
v8ian
Sept 16, 2020 7:06:41 GMT
I have always done well with Orbital Fasteners, Tel: 01923 777 777 Fax: 01923 779 169 E-mail:
slater
Club RR Member Number: 78
Imperial fixingsslater
@slater
Club Retro Rides Member 78
Sept 16, 2020 10:01:52 GMT
Problem is the stuff your looking for is probably not avalible. Best bet would be import from USA if you cant find it here.
bricol
Sept 16, 2020 11:01:56 GMT
5/8 UNC black nuts are certainly available easily - I could walk to the rack at work if I was in work and grab a handful, supplied by a local nut and bolt purveyor.
Coach bolts I have no idea I don't use them - but if longer ones are available, cut a longer one down.
My first point of call would be the Yellow Pages (or would if it still existed?) and find a local bolt and nut supplier/ironmonger and give them a call - you might be surprised what they can and will do.
Iainr
Sept 19, 2020 8:09:00 GMT
Some of the companies mentioned are ones that I had explored which suggests I am on the right track. I have come to the conclusion that trying to get everything I need from one supplier in a short timescale is too difficult, so I have split the order using many of the companies people have recommended.
I still can't find anyone selling 5/16"x1" UNC coach bolts and I think I will look into importing them from the USA. The coach bolts are needed to attach the fenders to a 1962 garden tractor. I could use metric and nobody would notice, but it would upset my OCD.
Many thanks for the comments and help Iain
v8ian
Sept 19, 2020 8:48:29 GMT
5/16 UNC thread is the same pitch as whitworth, thread angle is slightly different, so, you may be able yo use whit bolts?
