Bleach of lavant truck- And a local-ish farm shop that uses a similar colour scheme that got me thinking on it. Hi, That looks like Spruce Green, a 60s Ford colour as used on Mk1 Cortina's. A suitable homage to the trucks heritage. Colin
Bleach of lavant truck- And a local-ish farm shop that uses a similar colour scheme that got me thinking on it. Hi, That looks like Spruce Green, a 60s Ford colour as used on Mk1 Cortina's. A suitable homage to the trucks heritage. Colin I think it’s Proably just resida green or aircraft grey/green, both very common colours postwar due to military surplus. The inside of most bombers where painted that colour.
For those who have asked about loaded shots… First thing to go on was this- As you can see, it’s quite low. The grille shell clearance doesn’t matter much as it’s directly between the front wheels, but the main body is about 3” off the floor. It also has a very long wheelbase, 115”, that’s a foot longer than a stock model A. A bit of pushing and we’re ready to go. This is the money shot. As the weight of the front wheels gets to the top of the ramps, everything tips level for a pretty much straight shot up and on, which is exactly what I was aiming for. Obviously it varies a bit depending on how heavy each car is, but it’s in a ‘workable’ range for the 1-1.5ton stuff I work on. Then it get strapped on- And 150 miles later- Unloaded and tucked away in a actually reasonably sized but also already full of junk garage, making it a tight fit! Only gotta do that 10 more times or so…
Last Edit: Jun 9, 2022 19:52:48 GMT by Dez
braaap
I think it’s Proably just resida green Thought so, too. I just call it machinery green, after seeing so many machines from drills and lathes to other fabric gear like lockers or drawers. Wouldn't be my first choice, I'd rather combine that green with some yellow contrasts. But who am I ? Unloaded and tucked away in a actually reasonably sized but also already full of junk garage, making it a tight fit! Only gotta do that 10 more times or so… Wow, then that garage will be really full & tight fitted! Will You be able to drive the Lincolns with their looong rear overhang up there as easily?
Last Edit: Jun 9, 2022 20:12:54 GMT by braaap
Jun 10, 2022 22:15:53 GMT
I think it’s Proably just resida green Thought so, too. I just call it machinery green, after seeing so many machines from drills and lathes to other fabric gear like lockers or drawers. Wouldn't be my first choice, I'd rather combine that green with some yellow contrasts. But who am I ? I’ve got a thing for resida. The majority of my workshop equipment is it, and every time I refurb something that’s what colour it goes. Plus my front door and I’ll paint my gates to match too eventually 🤣 Unloaded and tucked away in a actually reasonably sized but also already full of junk garage, making it a tight fit! Only gotta do that 10 more times or so… Wow, then that garage will be really full & tight fitted! Will You be able to drive the Lincolns with their looong rear overhang up there as easily? Lincolns are gone. Largest vehicle I have now is a shoebox (16ft) or the 47 pickup, again about the same, or the falcon, also just under 16ft. So all will fit without issue.
Last Edit: Jun 10, 2022 22:16:35 GMT by Dez
Jun 12, 2022 11:30:21 GMT
Forgot to do this-
1. '28 model A ford 2. '48 chevy fleetmaster 3. '50 ford shoebox 4. ‘47 ford/ranger pickup 5. ‘63 ford falcon sedan delivery 6. ‘01 lupo tdi sport ✅ 7. 1981(?) bmw e28 8. ‘34 ford pickup 9. 1995 lada riva estate 10. ‘04 Transit recovery truck✅ 11. Fiat panda 100hp✅ 12. Peugeot expert van ✅
33.3% workingness. or a third in old money. Strong numbers so somethings Proably going to break pretty soon 😂
Jun 14, 2022 22:23:03 GMT
Once I’d warmed up with moving the model A, which was a pretty easy one in that it rolled and steered and was more or less in one piece, I decided to do probably the most difficult one on the list. This being the ‘34. It was difficult for a number of reasons, one being that it was welded to a chassis table that was on castors, two being that the body wasn’t really joined together or attached to the chassis, three it had no floors so I couldn’t put anything inside it. Oh and number 4 is the *slight* issue that the chassis table is 15 foot long. But the bed is 15 foot long I hear the more astute of you say- yes it is, but there’s a winch in the way for the first foot of it. So the back had to be blocked up with an overhang to allow me to remove the ramps, the body was partially bolted together and ratchet strapped down, and all the loose parts where removed and boxed up. Did I also mention I didn’t want to get it wet so I have to pick my day carefully? 😬 One major issue id not really considered was point loadings. Although I calculated it weighed about 1.5ton so I wasn’t overweight, the bed did NOT like have that entire weight on 4 small points. I’ve damaged the ally a bit at the back of the bed until I realised I needed to use ply to spread the load from the castors, moving the bits up the bed as i winched it on, which point-load a lot worse than a big ol’ inflated tyres do. The ramps have also taken an absolute hammering getting it on and off. I had two people to help me steer it on (castors are absolutely sh1te for doing such a thing, they’ll go any direction except the one you want them to) but I had to unload by myself. The journey itself was uneventful, here I am after another 150 miles. And here it is waiting to be unloaded. It was going in here temporarily, the concrete that’s supposed to be in that hole isn’t yet so I had to aim carefully with the ramps. The was LOTS of plywood involved to prevent further damage, it still slewed off the ramps twice and had to be jacked and levered back into place as castors are an utterly terrible invention unless you’re on a mirror smooth surface. Still, after a lot of swearing it was in the tent on the concrete and nobody died. Ramps took a hammering, but with a bit of further hammering they’re a bit better. The other vehicles should be easy after that! 😂
75swb
Beta Tester
Club RR Member Number: 181
Jun 14, 2022 23:28:40 GMT
Bloody hell that looks like a mission! I'd assumed woth your fleet numbers and move there would be a large workshop involved but is this not the case, or a later plan? Hope the rest of the move goes well anyway!
braaap
Respect!
Jun 15, 2022 20:27:26 GMT
Bloody hell that looks like a mission! I'd assumed woth your fleet numbers and move there would be a large workshop involved but is this not the case, or a later plan? Hope the rest of the move goes well anyway! It’s my next job after the move! I’d have liked to have built before but I was just stretched too thinly trying to make the house liveable and wrap up everything at the workshop 150 miles away as well as finishing the transit and making all cars transportable/getting rid of the ones I didn’t want. Once I have everything here I can more or less concentrate solely on building works.
Jun 15, 2022 20:42:08 GMT
In comparison, the next car was easy. Just winch it straight on and it didn’t even scrape, not bad to say it has 3/4” ground clearance. Repack any loose parts into boxes, strap the bonnet and boot shut, wedge the bumper etc. inside, and we’re good to go. And again, another 150 miles later- And unloading- It’s amazing how low a car this bed will take without issue. I think I’m justified in feeling smug about my design on this! The truck has also had a bit of extra love to finish off a few of the last rushed bits, I removed the rear mudguards and primed the brackets- Then topcoated them and refitted the guards.
maf260
Jun 16, 2022 12:46:05 GMT
In comparison, the next car was easy. Just winch it straight on and it didn’t even scrape, not bad to say it has 3/4” ground clearance. This is one build I'm looking forward to seeing progress on.
braaap
Jun 16, 2022 19:01:48 GMT
^^^ So does Dez I bet!
Jun 16, 2022 21:34:29 GMT
It’s a few down the list at the moment, there are more pressing builds to get sorted out first.
Jun 16, 2022 21:56:57 GMT
So with the truck on the road, I had some running issues with it. After I put it back together the glow plug light was flashing which is an indicator that there’s some sort of fault. It wasn’t there before so I figured it’s something I’d disturbed dismantling the front end. Driving it to the mot and back showed it was down on power, but there were no other symptoms- no noises or anything, and it always starts well. When reassembling I noticed the MAP was held into its pipework with zip ties, which pointed to an obvious place to start to me. Unplugging it did nothing, suggesting it was indeed duff. But rather than p1ssing in the wind I decided to code read it first. My reader wouldn’t read it at all, and nether would George’s. So I ran it down to my mate rikki across town as he also has a mk6 recovery truck, and a reader that’s known to work on it. Plugging it in gave me lots of codes. The battery was a bit low at this point due to lack of use, and it was acting a bit funny when trying to start. The battery got a charge and the codes were cleared, and I chucked on a new MAP from the transit breaker next door seeing as it was showing a MAP fault. With that done, the only codes that came back where these two- Now the temperature one is interesting, because these transits use a combined MAP and temp sensor. The guy at the breakers said ‘it’ll be the wiring not the unit’ and gave me one with some wiring still attached. Swapping just the unit sorted the MAP fault but not the temp sensor, and it’s highly unlikely both units would be faulty in the same way. Swapping the MAP and resetting the codes made the flashy light go out and netted a partial improvement, so I did the first couple trips like that. Slow on the long uphills, but not dangerously so, about 50mpg loaded which is only the same as the lorries could manage so I wasn’t making a nuisance of myself. I then got some time to do some fettling between trips, and I soldered in the replacement plug and a few inches of wiring. Ropey old plug- Old and ‘new’. New MAP with clips no made of solid rust like the old ones- And I’m happy to report it’s cured it. I hasten to say it’s fast, as it’s a 90ps transit, but it’ll hold its own now without slowing excessively as soon as you point it uphill at all! The last fault code? I’ve ignored it as no one actually knows what it means and it doesn’t seem to be causing an issue 😂
Club RR Member Number: 160
Watchdog code is most likely a wiring harness fault or it’s had the immo tampered with.
Jun 18, 2022 10:18:28 GMT
Watchdog code is most likely a wiring harness fault or it’s had the immo tampered with. It’s not one of the ‘your pump is about to die’ codes so I can live with it, especially as it doesnt seem to effect performance. It had a whole new engine/pump/ECU/immo package about 9 months before I bought it, all out of a minibus with only 39k. So it’s probably something to do with that swap I guess.
Jun 18, 2022 10:55:41 GMT
I suspect that last code is because the pump or ECU has been de-coded/virginised or whatever they call it.
'57 Austin Cambridge A55 1800 Overdrive '50 MG Y-type (In build) '56 Standard Super 10 (In build) '03 Fiat Stilo Abarth (Wet weather runabout) '03 Citroen Berlingo HDi (Parts hauler)
Jun 18, 2022 20:27:12 GMT
I suspect that last code is because the pump or ECU has been de-coded/virginised or whatever they call it. That is indeed a possibility, I don’t know what was done to fit the new engine but I guess something will have had to have been messed with, these things are actually pretty heavy on the electrics for a pre 2001 commercial vehicle.
Jun 18, 2022 20:50:04 GMT
Time for a bit more driving up and down the country. Check out at one end- Check in at the other- I did remove the front bumper off this one so I could nose it up to the winch by another 8” or so, but it is the longest vehicle I own. It’s starting to look like home now 😬😂 Push some cars round by meself in the megaheat (the phrase used was reet maftin, which you either get immediately or you’re not from Yorkshire) so I rewarded myself with a cornetto. And that’s another one down.
