I was going to just go in the deep end , but asking if there are any Bead rollers about makes more sense
I have never used one, but may just try some rolling soon, when making up the doors for the Rezin Rockit.
The idea is just to add some swage lines to give it a bit of strength.
And I suspect 1.2mm plate is the way to go.
Any advice for starting out, stuff to completely avoid, or pursue?
Thanks
Last Edit: Oct 3, 2020 17:30:43 GMT by grizz
slater
Club RR Member Number: 78
Any bead rollers out there?slater
@slater
Club Retro Rides Member 78
Using a hand cranked one on your own is very tricky and virtually impossible on a panel the size of a door skin.
I've got one of the versions made out of a piece of thick plate. Bought because I had never seen them as cheap, and was expecting to make new floors.
You're welcome to borrow it to figure out what you need. PM me
1.2mm thick steel probably wont be needed if you rolling beads in it
I've got one of the versions made out of a piece of thick plate. Bought because I had never seen them as cheap, and was expecting to make new floors. You're welcome to borrow it to figure out what you need. PM me 1.2mm thick steel probably wont be needed if you rolling beads in it Thanks Nick, Chatham is closer than Sheppey. Darren has offered his metal brake bender and bead roller, manual as well. I want some small steps in the leading and trailing vertical edges, in order to attach the nets. Not figured out how yet, unless purely by tension of frame is well planned.
The idea is just to add some sewage lines to give it a bit of strength. You're talking curse word!
Sorry, I couldn't resist...
How about a Shrinker/stretcher?
You can do a lot interesting sheetmetal work with a jigsaw, scraps of MDF or ply, clamps and hammers.......
The idea is just to add some sewage lines to give it a bit of strength. You're talking curse word! Spellchecker.
How about a Shrinker/stretcher? You can do a lot interesting sheetmetal work with a jigsaw, scraps of MDF or ply, clamps and hammers....... I think it’s all relative, what tools etc. I seem to be losing control already....... Making too much effort of something that was meant to be quick n,dirty.
How about a Shrinker/stretcher? You can do a lot interesting sheetmetal work with a jigsaw, scraps of MDF or ply, clamps and hammers....... I think it’s all relative, what tools etc. I seem to be losing control already....... Making too much effort of something that was meant to be quick n,dirty. You don't think gluing pieces of scrap ply together to fit the hole and hammering some sheetmetal over to quickly form your door frames isn't quick & dirty?
I think it’s all relative, what tools etc. I seem to be losing control already....... Making too much effort of something that was meant to be quick n,dirty. You don't think gluing pieces of scrap ply together to fit the hole and hammering some sheetmetal over to quickly form your door frames isn't quick & dirty? Absolutely. But welding flat steel plate to 10mm rebar is dirty too.
You're talking curse word! Spellchecker. Apologies again, your language skills put mine to shame
93fxdl
Enter your message here...
Would making the door frame from pipe be an option? Would give you a rigid frame which the webbing can be wrapped around Ttfn Glenn
Would making the door frame from pipe be an option? Would give you a rigid frame which the webbing can be wrapped around Ttfn Glenn Hi Glenn, I want the perimeter to be mainly rod, and then possibly a top pipe only to create a support for it all to hang from.
alecf
I've got one of the cheapy eBay ones. They work much, much better if you can weld on some beefy angle iron to reinforce them and stop them from bending. It's happy with 0.9mm steel, but didn't like 1.2mm much without reinforcement.
Brilliant results I was at a neighbor this afternoon and he has one too. Said I could use it. Looking forward to it.
I've got one of the cheapy eBay ones. They work much, much better if you can weld on some beefy angle iron to reinforce them and stop them from bending. It's happy with 0.9mm steel, but didn't like 1.2mm much without reinforcement. Still beats doing it by chasing lines with a hammer and chissel
