andyborris
Need a tyre inflator that can cope with a 4x4 tyre change, not just blow a few psi into it!
No spare wheel, just a spare tyre, so need one that'll be small, but can cope with setting the tyre onto the rim.
However, 12V or 240V is ok.
Any recommendations please?
Club RR Member Number: 160
Tyre InflatorRich
@foxmcintyre
Club Retro Rides Member 160
Need a tyre inflator that can cope with a 4x4 tyre change, not just blow a few psi into it! No spare wheel, just a spare tyre, so need one that'll be small, but can cope with setting the tyre onto the rim. However, 12V or 240V is ok. Any recommendations please? You need a high CFM for seating a bead. Something a compressor alone without a receiver vessel isn’t going to do easily. Do you have room for that on board?
andyborris
Not after something you'd use in a garage, however some of the more expensive ones claim 95L/MIN, not sure if that's enough though. linkOr there's always this, if nothing else, it'll scare the c**p out of the girlfiend!
