hopeso
Oct 16, 2020 11:19:07 GMT
Hi, A question for those who know about these things.
I have a new battery for a grass trimmer that won't take a charge. It is new so should work.
Can these be successfully dismantled and fixed?
hopeso
Oct 16, 2020 11:20:03 GMT
Oct 16, 2020 12:48:09 GMT
If you know your charger is good...... then this suggests the battery is either defective or too flat for the charger to recognise. Neither is great for a new battery so claiming warranty is probably the correct path.
However, if it’s “only” flat (and you should be able to establish this with a simple multimeter) you may be able to wake it up enough to get the charger to see it by applying something close to its rated voltage too it for a short while.
Nick
Oct 16, 2020 17:35:14 GMT
Hi, Be aware they do need a carefully controlled charge voltage otherwise they can burst into flames. Remember the hoverboards? That was down to charging problems.
Colin
