Hi all,
I've the following parts for sale
I live at DN18, Barton upon Humber North Lincolnshire if you wish to collect
if you want to call or text me 07894315304
Willwood master cylinder size 0.7 push rod changed to suit what I wanted so I could put a rod end on it. In good working order no leaks
£20 ono willing to post at buyers cost
Willwood master cylinder 0.625 no push rod, no leaks in good working order
X 2 Willwood master cylinders 0.625 both could do with re-sealing as slight weep seen from both spools
The two push rods altered to suit my brothers car set up
£35 ono willing to post at buyers cost
Willwood 0.7 master cylinder, good working order no push rod
X 2 master cylinder reservoirs, left hand side one never been out the bag so brand new. Right hand side one used but in good order, I drilled the top cap to allow the use of a pressure bleeder but it doesn't leak. Braided hose used but again good order with and its 1450 mm long. All do not leak
Triumph T675 throttle bodies, used on my Vauxhall 2.5 V6 engine worked well, home made machined bell mouths
Can be separated if required
£130 ono willing to post at buyers cost
Ram air filter used on my brothers 16V Vauxhall, no back plate but the threads are damaged> I was going to make a new back plate and re-thread it but never got around to it as I never used. Been oiled and stored in a bag for a couple of years still good. Slightly bent inside where the master cylinder pots pushed into it
£30 ono willing to post at buyers cost
Ford Sierra XR4X4 front calipers and discs, used but still good condition with plenty of life still in the discs and pads. Only removed as replaced with Cosworth four pot calipers and discs
£100 ono will post and buyers cost
Two oil pressure gauges
RMD is mechanical
VDO is electrical
£15 each
Willing to post at buyers cost
Sierra XR4X4 front hubs, drive shafts, open to offers
Sierra XR4X4 front sump open to offers
Sierra XR4X4 front diff open to offers
Sierra/ Escort Cosworth front prop shaft £150 ono
Thanks for looking, these will eventually end up on Ebay but putting them on here first
RMD is mechanical
VDO is electrical
£15 each
