Home made parts washer, can be fitted into a worktop like I did in the garage or make some sort of stand for it. The pump is from a small parts washer that you can submerge into the a container of water based cleaning fluid on the floor then just connect an hose to the nozzle and brush then the hose from the drain plug back to the container to complete the cycle job done you have a working parts washer. If fitted into a worktop just cover it with a board when not in use, then you have the workspace back.
You will need a 500mm x 400mm hole and sits 290mm deep
Collection from Dartford or Beckenham in Kent or can post
£35 collected or £45 posted
