First up apologies if this is the wrong section & not appropriate, it seemed the best place to ask.
For the first time in my life I'm soon to be in the strange (to me) position of having a decent income, but not very much free time, that combined with a boat project, potential house move, and a girlfriend means that I can't (or aren't allowed ) to spend all my time working on projects anymore.
So I'm looking for recommendations for somewhere to take the RX7 to have some work done, I don't mind paying a fair price for a good job, but obviously I'm looking to avoid getting ripped off or someone using my pride and joy as their learning curve!
A very rough project scope would be:
- Stripping the underside and epoxy priming / undersealing it
- Welding & fabrication as required from the stripping, the dreaded suspension mounts will definitely need doing & a hole behind them fixing.
- New fuel & brake lines running.
- Rear diff bearings replacing & pre-load resetting
There are other bits that need doing like suspension components that need blasting and powder coating, bushes doing etc, but stuff like that I can save time & money by dropping off at specialists myself if its work that would normally be outsourced anyway. The main work that needs doing is the fabrication & underbody, I just don't have time to learn to weld well enough to trust myself anywhere near it.
That got a bit long-winded, but is there anywhere in the Yorkshire area that people on here could recommend or have used before?
Thanks, Rich.
Thanks, Rich.
