Need some 70s wheels redrilled to from 4.5 to 6 inch PCD to fit on a Bedford CF. (both 5 stud) Strangely looks like they were once upon a time 6 inch PCD! Is there a company out there that can plug and weld the holes, and redrill (and mill the area around the face of the hole flat) ? Ideally a company that can also refurbish the wheels at the same time. I asked my usual wheel refurbishing place if they redrill wheels but they don't
I’ve not used these myself but they’re on my list for when I do need that service... www.tttoolsltd.co.uk/It looks like they don’t refurbish though just redrill, amongst other similar machining services.
You could try Ian Jemison he can weld and redrill wheels as well as refinish them. www.ianjemison.co.uk
Thanks, looking at Ian's website he doesn't seem to do diamond cutting of the faces (or doesn't mention it or show any photos of ones he's done) maybe I need to use two different places.
Thanks, looking at Ian's website he doesn't seem to do diamond cutting of the faces (or doesn't mention it or show any photos of ones he's done) maybe I need to use two different places. Worth giving them a ring to check, they may be able to do it but just not updated the website
Apr 11, 2022 11:20:36 GMT
Hi Datman
Apologies for dragging up an old thread, but did you find anyone to re-drill your wheels?
Co-incidentally, I also want some turbovecs, but (ironically) need them in 5 x 4.5!
Thanks
