Afternoon Gents..... and ladies if any present.
I have a quick decision, potential offer to buy this car for scrap value.
Owner has misplaced paperwork in his house or workshop. So it would be another £25.00 for a V62 generated V5c
Take a look at the past 10 years MOT History of fails, and latest MOT fail certificate online.........
Car has done 110k miles to date, and was a teenagers in current ownership.
Then think if it is worth buying and getting sorted for a youngster.
It lives 80 miles from me, so would need to be recovered.
MOT FAIL 2020
Do not drive until repaired (dangerous defects):
Nearside Rear Service brake has no recorded effort at a wheel (1.2.1 (a) (ii))
Nearside Front Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
Offside Front Tyre tread depth below requirements of 1.6mm (5.2.3 (e))
Repair immediately (major defects):
Rear Brakes imbalanced across an axle Axle 2 (1.2.1 (b) (i))
Monitor and repair if necessary (advisories):
Nearside Rear Tyre worn close to legal limit/worn on edge (5.2.3 (e))
Offside Rear Tyre worn close to legal limit/worn on edge (5.2.3 (e))
Nearside Rear Brake hose slightly deteriorated (1.1.12 (b) (ii))
Offside Rear Brake hose slightly deteriorated (1.1.12 (b) (ii))
Nearside Rear Brake pipe corroded, covered in grease or other material (1.1.11 (c))
Offside Rear Brake pipe corroded, covered in grease or other material (1.1.11 (c))
Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
MOT FAIL 2019
Windscreen washer provides insufficient washer liquid (3.5 (a))
Nearside Front All direction indicators incorrect colour (4.4.3 (a))
Offside Front All direction indicators incorrect colour (4.4.3 (a))
Offside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength outer sill (5.3.6 (a) (i))
Offside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength end of sill/ wheel arch (5.3.6 (a) (i))
Brake pipe corroded, covered in grease or other material front to rear at load valve (1.1.11 (c))
Rear tyres age cracking. not showing cords
MOT FAIL 2016
Reason(s) for failure
Offside Seat belt anchorage prescribed area is excessively corroded inner sil area (5.2.6)
Subframe mounting prescribed area is excessively corroded front crossmember (2.4.A.3)
Advisory notice item(s)
Rear registration plate deteriorated but not likely to be misread (6.3.1d)
MOT FAIL 2010 @80k miles
Nearside Front Direction indicator incorrect colour (1.4.A.2f)
Offside Front Direction indicator incorrect colour (1.4.A.2f)
Nearside Outer Front constant velocity joint gaiter split (2.5.C.1a)
Offside Outer Front constant velocity joint gaiter split (2.5.C.1a)
Nearside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Offside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Nearside Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Offside Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Thanks
MOT FAIL 2020
MOT FAIL 2019
MOT FAIL 2016
Thanks
