Jan 11, 2021 21:24:04 GMT
So i have bought a ford ranger sump to fit my duratec engine that is going in my bmw. Sump is at the back, and i think the pick up pipe will sit in the middle [not so sure as its still in teh post from america!] But the question is, how to stop oil surge? Can anyone give me some pointers please? I was told years ago about the xe to put a plate over all the bowl , put a hole in it for the pick up pipe say 4" around, then put a 1" lip going down . but not sure what to do here really thanks!!
Your plan sounds spot on. On my Escort I just have the plate without the lip, but the lip can only make it better. I did weld a box on the side that adds more oil capacity, but this was mainly because I cut a chunk out of the sump to clear the crossmember.
Jan 12, 2021 10:00:58 GMT
What is best for around the edges of the plate ? Gap or welded in ? Thanks
Jan 12, 2021 11:38:49 GMT
Can you weld aluminium? Or know someone who can? Making up something like this is cheap and easy, these are from Burton racing. Weld it to the base of the sump where the pick up pipe goes.
Jan 12, 2021 17:29:34 GMT
thats interesting as there is ways for the oil to return into the sump aswell. part of me is thinking ill mod it and make it worse as teh oil cant get back in!
thanks!
Jan 13, 2021 20:16:02 GMT
how far from the botton of the sump does the tube sit? thanks
Jan 13, 2021 21:13:34 GMT
For the Burton style it can be welded to the base of the sump, that's what the side holes are for, to provide a constant pool of oil.
Jan 13, 2021 21:45:04 GMT
right thankyou! are they maybe like 25mm holes cut downwards? thanks.
ferny
Club RR Member Number: 13
baffling sump problem.ferny
@ferny
Club Retro Rides Member 13
Jan 13, 2021 22:30:33 GMT
I'm slightly confused.
From the picture and your words, are you trying to work out how to stop oil surge whilst having the pick-up from the shallow area of the sump? If so, change the pick-up so it's in the cooler reserve of oil in the deeper area.
If not, then ignore me and go with the above. 🙂
Last Edit: Jan 13, 2021 22:31:00 GMT by ferny
I'd hope that the pickup pipe you have coming will reach into the deep part of the sump. If it doesn't, it is different to every other engine in the world, which doesn't sound like a sensible design to me.
If you think it needs further baffling, the suggestion you first made is the best. For oil to move sideways under cornering, it also has to rise up. By putting a horizontal baffle all the way around the sump and pickup, just above the full oil mark and fully sealed to the sides, the oil is prevented from rising up out of the sump oil collection area. The hole in the centre should just be big enough for the pickup and with a turned down lip. Most OEM sumps I've seen are built this way.
v8ian
What do you intend to use the car for?
baffling sump problem.stealthstylz
@stealthstylz
Club Retro Rides Member 174
Jan 14, 2021 18:48:24 GMT
The pickup pipe sits slightly towards the front of the bowl in the sump. I've never tried it but I think the easiest way to mount a baffle would be to make a plate up similar to your idea then split it in half and weld it to the pickup pipe. You'd have to weld some bosses onto the sump to fasten it to otherwise.
Jan 14, 2021 18:59:31 GMT
oh i see, sorry i have ordered the right pick up to match the sump, its from the ranger too! so it sits in the back where the pinto type does.
Jan 14, 2021 21:33:56 GMT
What's the gear above the pick up on the crank? Never seen that before on a zetec/duratec.
Jan 14, 2021 21:43:35 GMT
not sure, but it is a 2.5 engine, the owner is from america and its in a mercur? sierra! as a guess its a crank sensor?
Jan 14, 2021 21:48:39 GMT
it is for a balance shaft
mk2cossie
Club RR Member Number: 77
baffling sump problem.mk2cossie
@mk2cossie
Club Retro Rides Member 77
Jan 15, 2021 14:19:24 GMT
What's the gear above the pick up on the crank? Never seen that before on a zetec/duratec. As said above this post, the 2.3 has a balance shaft assembly that bolts up to the bottom of the crankcase and is driven by the chuffing great big gear on the crankshaft
Jan 15, 2021 15:58:47 GMT
has anyone here used the pumasport r190 cosworth cams?
Jan 30, 2021 18:10:07 GMT
so i had a go at the sump today, made the plate in steel, and it bolts to 4 pedestals that are cast into the sump itself. the tube is open to the front corner as its quite enclosed there. the bowl part is the rear of the set up, it is RWD in the bmw too. what do you recon then?
Jan 30, 2021 18:58:45 GMT
Looks like it'll work, what size are the holes to feed the base of the pick up.
