gte86
Apr 16, 2021 20:40:47 GMT
Last Edit: Apr 16, 2021 21:07:17 GMT by gte86
gte86
Apr 16, 2021 20:42:37 GMT
Next the car came home so I could do bits once the kids are in bed. First on the list interior lights. Lots of leds ordered Puddle lights before And after
Last Edit: Apr 16, 2021 20:44:22 GMT by gte86
2003 E39 530i Touring ballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Apr 16, 2021 20:47:43 GMT
That diff oil is not meant to be service item. It's so much darker than new oil.
gte86
Apr 16, 2021 20:57:15 GMT
gte86
Apr 16, 2021 21:05:12 GMT
Waiting on parts now. I have one broken headlight adjuster so I've got a kit to change both sides and I'll polish them while they are out. I've got new aftermarket arch liners for when the bumper is off. Then the big jobs start. I've ordered . . . . Full X8R vanos rebuild kit FEBI CCV kit Water pump, Thermostat and top hose Castrol 5w30 LL and mahle filter Inlet and rocker gaskets Oil filter housing gaskets and vacuum hoses
The plan is to pull it all apart and replace the bits while it's off the road, hopefully giving me a few years head start on the running costs. I will do a full coolant flush and another brake fluid flush while it's on the ramp. I flushed 3 litres of brake fluid out already but its still not as clear as I would like.
This isn't a big money build, I'm hoping I can do as much before it's in daily use as possible to limit breakdowns and unexpected bills. It's got new brakes all round and the suspension actually looks OK. Slight rust on the inner sill but I'll look at that over winter. I'm hoping to drive for 6 months or so now and then pull apart for a suspension and brake line overhaul over winter.
gte86
Apr 16, 2021 21:12:17 GMT
Lots of the pics are in the wrong order 😕
gte86
Apr 16, 2021 21:13:41 GMT
That diff oil is not meant to be service item. It's so much darker than new oil. The gearbox is 'sealed for life' too but fresh oil works wonders
@ballbagbagins
Apr 16, 2021 21:23:32 GMT
Agreed. My e46 touring auto was much smoother after a gearbox service. It took I think 6 litres to fill, not cheap but noticeable.
I also felt an improvement after changing the pas fluid.
gte86
Apr 16, 2021 21:30:53 GMT
I got the febi filter and 5 litres of oil for something ridiculous like 35 quid. I had a litre of oil on my toolbox anyway so plan on throwing that oil in for now and then change it again after a few miles. Work let me use the ramp in my own time and I have access all hours so I feel a few night shifts coming on.
gte86
Apr 16, 2021 21:34:55 GMT
And the towbar is coming off for now. Once Covid has relaxed I'm going to sit a trailer test so I can take dad's hot rod and Model A to shows and hoping to get as many as possible to the Gathering
jjeffries
Apr 16, 2021 23:52:00 GMT
Excellent car. I worked at a BMW dealer (in the US) when these were new and ran a wagon/estate/Touring as our road-service vehicle. To my mind the e39 was an end-of-era car; many BMW car-making things just got silly after.
I will be following your progress.
Thanks and best of luck to you.
John
gte86
Lots of parts. Ive got a green air filter in there too. Just waiting for some gaskets from autodoc and the vanos kit from x8r and I can get stuck in. Think I'm going to do the Disa repair kit from x8r as well but that will have to wait. Had an email this morning to say the bumper is arriving Tuesday
gte86
Apr 19, 2021 19:44:29 GMT
Vanos kit has arrived. Hoping to get the oil filter housing gasket and vanos gasket delivered by the wkend so I can have some late nights at work throwing it all together
Watching with interest, I think we’re both on the same path with maintenances etc.
Where did you source your wheel arch liners from?
Apr 20, 2021 11:06:52 GMT
looking great. I've changed the box oil 3x in 80k miles on mine, it's just got carplan dexron 3+ in it now and seems fine. I'd do the power steering hoses and bottle too as the parts are cheap and they always leak. And if you are pulling the rad to do the belts/ water pump, it'd be worth a once over of the condenser, trans cooler and O rings. I did all the rear arms recently, but there still seems to be some movement, so it'll need investigating soon
oh and a new thermostat housing is often required
gte86
Apr 20, 2021 13:32:27 GMT
Watching with interest, I think we’re both on the same path with maintenances etc. Where did you source your wheel arch liners from? I went for some ebay ones from Latvia. They are quite shiny so if they fit OK I might try to flat them back and dull them. I'll let you know my thoughts on them.
gte86
Apr 20, 2021 13:35:21 GMT
looking great. I've changed the box oil 3x in 80k miles on mine, it's just got carplan dexron 3+ in it now and seems fine. I'd do the power steering hoses and bottle too as the parts are cheap and they always leak. And if you are pulling the rad to do the belts/ water pump, it'd be worth a once over of the condenser, trans cooler and O rings. I did all the rear arms recently, but there still seems to be some movement, so it'll need investigating soon oh and a new thermostat housing is often required I'm falling into a worm hole of buying parts already. I'll get a bottle and pas hose as mine as wet. I have had the car over a month and haven't even driven it yet. I hope I like it when it's done ha
gte86
Apr 20, 2021 13:36:39 GMT
I've got some bits I need to sell from the garage soon so I'm going to look for a rear subframe from a breaker. I've decided it would be easier to have that and replace parts onto it and then swap the whole lot and do brake lines at the same time. I'm a glutton for punishment it seems
Apr 20, 2021 14:05:36 GMT
good plan, it's an absolute doing the arms in situ, the camber bolts are always solid. Might be worth scouting around for an LSD if you have the diff off the you can weld up the jacking points and have room to do the brake lines am I helping....I absolutely love mine, but it needs the front jacking point doing now, always something
gte86
Apr 20, 2021 14:36:37 GMT
good plan, it's an absolute doing the arms in situ, the camber bolts are always solid. Might be worth scouting around for an LSD if you have the diff off the you can weld up the jacking points and have room to do the brake lines am I helping....I absolutely love mine, but it needs the front jacking point doing now, always something Not helping in the slightest. This car is gonna get expensive with all the parts I'm changing 'while I'm there'
