I have ended up with a SPA Design Shift Light but no wiring or instructions.
Had a search on the internet and came across the spatechnique.co.uk/ website & there is a technical section with instructions for older models so thought it was going to be easy to get it working.
No such luck.
The instructions for the older models are on spatechnique.co.uk/pages/older-product-documents so downloaded the instructions for the shift light but instructions refer to 8 pins on the wiring where the unit only has 7 pins.
I have emailed to ask but not got a reply as of yet.
Has anyone used one and possibly got the instructions?
I have removed the screws & had a quick look to see if there was a possible clue inside or if the PCB was screen printed or marked but no such luck this time.
Bought a 7 pin DIN plug which fits nicely just need to find out the wiring.
No massive loss if it cant be found or doesn't work but would use it with the new project if it can be got working.
