I am finally getting round to fitting the M series engine and Lt77 gearbox to my B so the current engine, gearbox and all associated parts are available.
Engine still fitted so happy to take prospective buyers for a test drive, powerful engine, brilliant upgrade to any MGB, perfect for someone who needs to renew a worn out engine and is looking to upgrade all in one.
Located in Glasgow, happy to deliver or put on a pallet for collection.
Any questions please get in touch.
Spec
1860cc built by Motobuild
Fully balanced bottom end
717 scatter cam
Duplex timing gear
stage 3 big valve unleaded head
ARP studs
To include:
Rebuilt 1 3/4" SU carbs and velocity stacks
Stainless heat shield
Jenvey airbox
Uprated clutch
Rebuilt gearbox and overdrive unit
Large capacity 4 row radiator
Oil cooler and lines
Upgraded distributor with Luminition Optronic ignition
Sport coil
Facet fuel pump
Filter king fuel filter and regulator
Reconditioned prop
Alloy rocker cover
Peco HDR manifold and system, custom 3" tip
Engjne and gearbox mounts
Fuel tank
£2750ono
Spec
717 scatter cam
Duplex timing gear
ARP studs
To include:
Jenvey airbox
Uprated clutch
Sport coil
Facet fuel pump
Reconditioned prop
Alloy rocker cover
Fuel tank
£2750ono
