ferny
Club RR Member Number: 13
I think my eBay FPR is giving out. Well, I hope it is and its not the pump! Are the Sytec ones any good? I see loads for sale and it's a brand I vaguely recognise. Are there any better options in the same price bracket? It's going on a turbo MX5 engine.
Last Edit: Sept 7, 2021 1:14:07 GMT by ferny
ferny
Sept 10, 2021 17:07:02 GMT
Well, I got one.
I'll report back later with findings. I did notice that the bottom is branded Malpassi.
Sept 10, 2021 18:15:20 GMT
I have one on my MR2 and it always worked well while it was on the road. would buy them again.
Sept 11, 2021 10:59:25 GMT
no, pointless 'upgrade' stick an appropriate oem style regulator on and be done with it, you should never need to adjust the pressure on fuel injection systems.
ferny
Sept 11, 2021 15:29:21 GMT
no, pointless 'upgrade' stick an appropriate oem style regulator on and be done with it, you should never need to adjust the pressure on fuel injection systems. I'll remove the turbo and fit the original 60bhp engine back in then. 👍
Last Edit: Sept 11, 2021 15:29:44 GMT by ferny
Sept 11, 2021 17:02:08 GMT
why would you do that?!
Paul Y
Sept 11, 2021 18:22:31 GMT
Sept 11, 2021 19:09:44 GMT
no, pointless 'upgrade' stick an appropriate oem style regulator on and be done with it, you should never need to adjust the pressure on fuel injection systems. What a pointless comment. There is many reasons someone might need a fuel pressure regulator. I use one to convert from a return style fuel system to a none return fuel rail since its a none standard engine.
Sept 11, 2021 20:52:00 GMT
I've been using one for a while without any problems
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
ferny
Sept 12, 2021 6:53:33 GMT
If that's the type with the hard plastic diaphragm, then that's what I've removed. It'd been on for about 3.5 years and I've never been able to get my AFR to read consistently. Recently it's been running lean without rhyme nor warning. It'd be fine, then decide to set itself at 18-1. I stripped the FPR down to find nothing actually wrong but decided to replace it anyway. It was on my list to upgrade and the cheap one was only bought to prove a principle. So far, AFR seem stable and consistent. I have only driven a few miles though.
Last Edit: Sept 12, 2021 10:44:31 GMT by ferny
Paul Y
Sept 12, 2021 17:29:50 GMT
Nope. It’s a soft rubber diaphragm. Have a look at my thread where I took it apart to clear it out when it sprayed fuel everywhere on first start up. I just bought the one that all the other Turbo LS guys purchased. P.
Last Edit: Sept 12, 2021 19:10:03 GMT by Paul Y
Paul Y
Sept 12, 2021 17:31:45 GMT
