I was browsing around for something else and came across this rather interesting thread : www.garagejournal.com/forum/threads/the-truck-tool-equivalents-thread-2-0-expanded-with-part-numbers.249851/
It details how stuff is re-branded, available as different brands at (usually) cheaper prices.
A lot of this stuff is focused on trucks and US tools (imperial sizing and all that). I'm wondering if there is something already existing for metric tools, or something we could put together by us?
Here is the second post from the thread, the Snap-On selection to give you an example of what they are doing, the Snap On item is on the left, the alternative on the right:
Snap-on/Blue Point
Ratchets:
T72 1/4" Ratchet - Bahco 6950 (72 Tooth)*
F80 3/8" Ratchet - Bahco 7750 (80 Tooth)*
S80 1/2" Ratchet - Bahco 8150 (80 Tooth)*
*Bahco version only offered in comfort grip.
T936 1/4" Ratchet - Williams M-52EHA, CAT 239-6823 (36 Tooth)
TL936 1/4" Long Ratchet - Williams M-52EHLA (36 Tooth)
TF936 1/4" Flex Ratchet - Williams M-52EHFA (36 tooth)
F936 3/8" Ratchet - Williams B-52EHA, CAT 239-6824 (36 Tooth)
FL936 3/8" Long Ratchet - Williams B-52EHLA (36 Tooth)
FLF936 3/8" Flex Ratchet - Williams B-52EHFA (36 tooth)
S936 1/2" Ratchet - Williams S-52EHA, CAT 239-6825 (36 Tooth)
SL936 1/2" Long Ratchet - Williams S-52EHLA, CAT 239-6826 (36 Tooth)
SF936 1/2" Flex Ratchet - Williams S-52EHFA (36 tooth)
BPRTR936 1/4" QR Ratchet (Blue Point) - Williams 30001, Westward 4YP73 (36 tooth)
BPRFR938 3/8" QR Ratchet (Blue Point) - Williams 31001, Westward 4YP74 (38 tooth)
BPRSR940 1/2" QR Ratchet (Blue Point) - Williams 32001, Westward 4YP75 (40 tooth)
BLPCGHD146 1/4" Drive 6" Spinner Handle (Blue Point) - Williams 30006
BLPCGHD388 3/8" Drive 9" Spinner Handle (Blue Point) - Williams 31016
TM4CSA 1/4" Drive 6" Spinner Handle - CAT 9S-1722
BLPPTSS3822 3/8" Drive Pass Through Ratchet/Socket Set (Blue Point) - Williams 50671
Torque Tools:
TQR100B 3/8" Drive Click Torque Wrench (20-100 ft/lbs) - Precision Instruments C2R100F
TQFR100C 3/8" Drive Flex Torque Wrench (20-100 ft/lbs) - Precision Instruments C2FR100F
TQFR50B/C 3/8" Drive Flex Torque Wrench (100-600 in/lbs) - Precision Instruments C2FR600H
TQFRN68B 3/8" Drive Flex Torque Wrench (14-68 Nm) - Precision Instruments C2FR68N
TQFRN130B 3/8" Drive Flex Torque Wrench (25-135 Nm) - Precision Instruments C2FR130N
TQR250E 1/2" Drive Click Torque Wrench (40-250 ft/lbs) - Precision Instruments C3F250F
TQFR250E 1/2" Drive Flex Click Torque Wrench (40-250 ft/lbs) - Precision Instruments C3FR250F
TQFRM34D 1/2" Drive Flex Click Torque Wrench (5-34 kg.m) - Precision Instruments C3FR34M
TQFRN350D 1/2" Drive Flex Click Torque Wrench (60-350 Nm) - Precision Instruments C3FR350N
TQR400E 3/4" Drive Click Torque Wrench (130-400 ft/lbs) - Precision Instruments C4D400F
TQR600E 3/4" Drive Click Torque Wrench (200-600 ft/lbs) - Precision Instruments C4D600F
TQRM80C 3/4" Drive Click Torque Wrench (26-80 kg.m) - Precision Instruments C4D80M
Wrenches:
BLPCWS711B 11pc BP Combo Wrench Set (3/8"-1") - Williams 11007
BOER704 4pc BP Reversible Ratcheting Combo Set (13/16"-1") - Williams WS-1164RC
BOER708 8pc BP Reversible Ratcheting Combo Set (5/16"-3/4") - Williams WS-1168RC
BOERM712 12pc BP Reversible Ratcheting Combo Set (8mm–19mm) - Williams MWS-12RC
BOERMF712A 12pc BP Flex Reversible Ratcheting Combo Set (8mm-19mm) - Williams MWS-12RCF
BOERF708A 8pc BP Flex Reversible Ratcheting Combo Set (5/16"-3/4") - Williams WS-1168RCF
GAJS30A 30" Adjustable Wrench, Industrial Finish (Blue Point) - Bahco 87
VS814A 14pc SAE Open End Angle Wrench Set (3/8" - 1-1/4") - CAT 1P-3515
Screwdrivers:
SSDMR4B Ratcheting Screwdriver - Williams WRS-1, CAT 9U-7291, Case IH SC80005
SSDMRT1 2" Shank T-Handle Ratcheting Screwdriver - Williams WRST1
SSDMRT4 4" Shank T-Handle Ratcheting Screwdriver - Williams WRST4
SSDMRT8A 8" Shank T-Handle Ratcheting Screwdriver - Williams WRST8
SSF1/SSFP1/SSFP2 3pc Ultra Low Profile Screwdrivers - Anex 6102T
Pick Sets:
PSLR4 4pc Hook & Pick Set - Ullman CHP4-L, Matco CHP4L, Craftsman CHP4-L, MAC PSCHP4L
PSLR6 6pc Hook & Pick Set - Ullman CHP6-L, Matco CHP6L, MAC PSCHP6L
Hex & Torx Key Sets
AWEF6K 6pc SAE Folding Hex Key Set (5/32"-3/8") - Eklind 25611
AWEF9K 9pc SAE Folding Hex Key Set (.5"-3/16") - Eklind 25912
AWMEF6K 6pc Metric Folding Hex Key Set (3-10mm) - Eklind 25161
AWMEF7K 7pc Metric Folding Hex Key Set (1.5-6mm) - Eklind 25171
AWMEF8K 8pc Metric Folding Hex Key Set (2-8mm) - Eklind 25181
AWTEF8K 8pc Torx Folding Hex Key Set (T8-T40) - Eklind 25581
BHM9A 9pc Metric Ball End Hex L-Key Set (1.5-10mm) - Eklind 13609
BHS13A 13pc SAE Ball End Hex L-Key Set (.5"-3/8") - Eklind 13213
Pliers:
BDG96LMP (Blue Point) Mini Long Reach Long Nose Pliers - Williams 23471
BDG86LMP (Blue Point) Mini Long Reach Diagonal Cutter - Williams 23473
BDG9645LMP (Blue Point) Mini Long Reach Bent Nose Pliers - Williams 23475
BDG97LMP (Blue Point) Mini Long Reach Needle Nose Pliers - Williams 23477
BDGPL400LMP (Blue Point) 4pc Mini Long Reach Pliers Set - Williams 23064
PHP3 Mini Hose Pinch Pliers - Craftsman 47050*, Imperial HP54, KD 3791, SK 7601, Matco HP54
PHP1 9" Hose Pinch off Pliers - Craftsman 47051*, Imperial HP55, KD 3792, SK 7602, Matco HP55
PHP2 Heavy Duty Pinch Pliers - Craftsman 47060*, Imperial HP56, KD 3793, SK 7603, Matco HP56
*All 3 in Craftsman set 74Z706
PL300CF 3 pc Pliers/Cutters Set - CAT 233-1639
47ACF Slip Joint Pliers - CAT 6V-6192
87ACF Diagonal Cutters - CAT 6V-6193
96ACF Needle Nose Pliers - CAT 6V-6194
PRH406 6pc Camlock Retaining Ring Pliers Set - Imperial Stride IR-6CK, Matco MST4306, SK 7780, Urrea 370L, Craftsman 950465, Armstrong 68-056
PR50A 2pc Heavy Duty Replaceable Tip Retaining Ring Pliers Set (Blue Point) - Imperial Stride IR-50K
PRH503 3pc Quick Switch Snap Ring Pliers Set - Lang 1465, Channellock RT-3, Craftsman 47394, Matco SPRC3A, Wright 9H1265K
PWZ0 8-7/16" Pliers Wrench 1-3/16" Jaw - Bahco 140
PWZ1 11" Pliers Wrench 1-3/8" Jaw - Bahco 141
PWZ2 14-1/2" Pliers Wrench 2-1/16" Jaw - Bahco 142
PWZ3 21-7/8" Pliers Wrench 3-1/16" Jaw - Bahco 143
PWZ4 28-3/8" Pliers Wrench 4-3/8" Jaw - Bahco 144
PWZ5 41-3/4" Pliers Wrench 6-5/16" Jaw - Bahco 147
LP5WR 5" Locking Pliers Curved Jaw w. Cutter - Grip-On GR12105
LP7WR 7" Locking Pliers Curved Jaw w. Cutter - Grip-On GR12107
LP10WR 10" Locking Pliers Curved Jaw w. Cutter - Grip-On GR12110
LP6LN 6" Locking Pliers Long Nose - Grip-On GR12706
VGP23312 12" Locking Clamp with Self Leveling Jaws - Grip-On GR23312
VGP13709 9" Locking Plugweld Pliers - Grip-On GR13709BK, NAPA P821
VGP14412 12" Aluminum Locking C-Clamp - Grip-On GR14412
YA824ASTR (Blue Point) Spark Plug Boot Pliers - SE Tools 824S, Matco SP824S
YA824C (Blue Point) 45° Spark Plug Boot Pliers - SE Tools 824A, Matco SP824
SBP5 (BLue Point) 5-Position Spark Plug Boot Pliers - Lisle 51750, Matco LS51750
Air Tools:
FAR2500 1/4" Mini Air Ratchet - Sioux SRW03S25
FAR2505 3/8" Mini Air Ratchet - Sioux SRW03S38
Hammers:
BC7B 5lb Deadblow Sledgehammer (Blue Point) - Trusty Cook #7
BC110B 8lb Deadblow Sledgehammer (Blue Point) - Trusty Cook #10
BC114B 11lb Deadblow Sledgehammer (Blue Point) - Trusty Cook #14
BD10ESG 10lb Fiberglass Handle Sledgehammer (Blue Point) - Williams SHF-10L
Damaged Nut/Bolt Removal, Thread Cutting/Repair:
ATSSET 2pc Adjustable Tap Socket Set - Irwin 3095001, Matco ATS2
E1020 20pc Extractor Set - Ridgid 35585
EXD35 35pc Drill Bit and Extractor Set - Irwin 11135
EXDL10 Left Hand Extractor Set - Irwin 11119
EXD35 35pc Master Extractor Set - Irwin 11135ZR, Matco MEX35, Cornwell ATC11135, MAC SCEX35S
EXDMS48 48pc Master Extractor Set - Irwin 3101010, Cornwell ATC3101010
RTD40 40pc Master Rethreading Kit - Kastar 972, Craftsman 52105, MAC TRCOMBO
RTD48 48pc Master Rethreading Kit - Kastar 971, Craftsman 42275, MAC TRCOMBO-48
TDTDM117A* 117pc Tap/Die & Drill Set - Irwin 26377, Matco 676TDP, MAC TDPLUS, Cornwell VG1813817
TDTDM500A* 76pc Tap/Die Set - Irwin 26376, Matco 676TD, MAC TDCOMBO, Cornwell VG1813816
*Snap-On sets include adjustable dies
Specialty Tools:
BTCP500 Brake Caliper Press - Kastar 279
BTWSMPK 7pc Bit Ratchet Wrench Set - Kastar KAS5220, Matco FTR7, Craftsman 47477
CJ1200 Slide Hammer Dent Puller Set - Keysco 77081
FB310B 25 Blade Master Feeler Gauge Set - Craftsman 40804, Proto J000AA, MAC FG002
FB325A 6 Blade Non-Magnetic Feeler Gauge Set - Proto J000BR, Matco FG23A
GA285 Camshaft Bearing Tool Kit - Lisle 18000, Matco CBT18, MAC CBT18A
GA486A Battery Terminal Puller - Lisle 54150, Matco BT54150, MAC BP21K, Cornwell ECBK706
HP200 Pop Riveter kit - Marson 39001
LDT8 18pc AC/Fuel Line Master Disconnect Set - Lisle 39900, Matco MDS399, MAC MD4000
LCSS600 Steel Line Stopper Kit - Private Brand Tools PBT71106, Cornwell PBT71106, Matco SLSK90
LKP620 Master Lock Pick Set - Lock Technology LT620
PGH8A 11 Piece Gasket Cutter Set - Kastar 950, Matco 79PK, MAC GC950
TF5A Double Flaring Tool Set - Wilde 250DF, MAC FT158B, NAPA 41860
TORCH6 Mini Butane Torch - Portasol TORCH820 (012680040)
TT12KT 12pc Terminal Tool Kit - Sealy VS920, Proto JFE96030, Matco TTK031, MAC TT96030, Cornwell JS96033
TT3K Terminal Tool Set with Handle - Lisle 57750, Matco TWT577, MAC TT7750
YA105 Seal Puller (Blue Point) - Lisle 56750, Craftsman 947645, Matco SP56
YAKS32A Butane Soldering Iron - Portasol/Weller PSI100K
YA832A Spark Tester - Lisle 19380, Matco SPT79
YA840 Inline Spark Tester - Lisle 20610, Matco ST20610
Funnels
OFHARLEY Harley 2007+/Kia Threaded Funnel - Assenmacher OFHD35
OFHD Harley 1999-2006 Threaded Funnel - Assenmacher OFHD419, Matco OFHD419
OFFM Ford/Mazda Threaded Funnel - Assenmacher ASMOFFM2012
OFHON33 Honda/Nissan/Chrysler/Ford Threaded Funnel - Assenmacher ASMOFHON1033, Matco HON1033
OFTOY38 Toyota Threaded Funnel - Assenmacher OFTOY1038, Matco TOY1038
OFGMFORD GM/Ford Threaded Funnel - Assenmacher ASSOFGMRD08, Matco GMRD08
OFKIT 5 pc Master Oil Funnel Kit - Assenmacher FUN14KIT
Shop Equipment and Tool Storage
AWSTAND T-handle Hex/Allen Key Rack - Williams HKTSTAND, McMaster-Carr 53045A36
BPTRYLAS 76pc Lock-a-Socket Tray - Mechanics Time Saver MTSLASTRAY
KMAGBIT37R Magnetic 37 Hole Hex Bit Organizer - Mechanics Time Saver 581, Torin 581T
KRBC2T 2 Shelf Roll Cart (Blue Point) - Williams 50722
KRBC3TD 2 Shelf Roll Cart w. Locking Drawer (Blue-Point) - Williams 50723
KRBC7TD 4 Drawer Roll Cart with Lid, Rack and Shelf (Blue-Point) - 50724
NOTES:
Snap-On Chrome Sockets - Williams USA Chrome Sockets, No direct set crossover.
Blue Point Chrome Sockets - Williams Taiwan Chrome Sockets, No direct set crossover.
Snap-On Torx Insert Bits - Zephyr Torx Insert Bits
Snap-On Bench Vises (Part Number WV####) - Wilton #### (Example: WV300N = Wilton 300N)
Snap-On Drill Bits - Triumph Twist Drill Co. Bits
Snap-on/Blue Point
Ratchets:
Torque Tools:
Wrenches:
Screwdrivers:
Pick Sets:
Hex & Torx Key Sets
Pliers:
Air Tools:
Hammers:
Specialty Tools:
Funnels
NOTES:
