Dec 14, 2021 22:22:04 GMT
Here are a few pics of the restored suspension setup... Front is basically a complete Satchell setup, uses a modified GTi subframe (which we modified again since these pics to clear the box), with a nos PAS rack. Front hubs are Pug 406 with 50mm bump steer and roll centre correction, Satchell rose jointed steering arm ends welded to new 309GTi steering arms, and custom rose jointed satchell wishbones Front inserts are 50mm bilstein tarmacs The rear is where it really gets interesting. It's a one-off setup base on a toyota corrolla wrc setup. Toyota rear beam modified to mount 4 parallel arms and two trailing arms mounted inboard forward of the front wheels. Not sure what the hubs are but they are pretty small, all rose jointed except for the lower hub trailing arm mounts. Rear shocks are avo with custom lowwrs to fit the hubs. Note the car does not run anti roll bars with the suspension and spring rates setup to account for that. Down the line, I may upgrade to 2 or 3 way shocks with remote reservoirs. I dropped the hubs off today for their custom brake adapters and bells. Running AP Racing cp5200 with 330mm x 28mm front and Sierra Cosworth 4wd rear (287mm vented i think) - everything brand new except the ap calipers (because they would have been £££ and found a good used set for comparative peanuts!)
Last Edit: Dec 17, 2021 9:20:47 GMT by chodjinn
Did you sort the roof welds out before you put the new roof on? I think you mentioned it was a Custom Cages / Satchell shell? They've both been guilty of sub-standard welding..
Also recommend Flickr if you're a mobile user.. imgur isn't the best for embedding images, as you can probably tell!
Good lord this is a cool car To get the photos to come thru set out the link like this
Last Edit: Dec 17, 2021 13:28:50 GMT by metroman
Dec 15, 2021 10:10:04 GMT
Apologies if they're not quite in the right order! Well done mate excellent work. Advice on how to do that for my next post please? Have more pics When using IMG, go to the photo you wish to post. There will be three dots in the top righthand corner, click that and select "get share codes" then select the BB code (for forums), then copy and paste the code into your post Regardless, the 205 looks totally mega!
Good lord this is a cool car To get the photos to come thru set out the link like this Tried it, doesn't work. I've had a few goes at this now, I can't get it to do anyhting other than post a link. The imgur app is utterly rubbish. I tired the Flixr app before Imgur, it's even worse, the app does not work on my phone and cant upload more than 1 picture at a time via laptop. Getting rather annoyed about this now tbh, bah!
Last Edit: Dec 16, 2021 8:05:09 GMT by chodjinn
Also recommend Flickr if you're a mobile user.. imgur isn't the best for embedding images, as you can probably tell! Yes we went through the entire shell as best we could. Most of the welds were ok, if a little messy.
jonomisfit
Club RR Member Number: 49
Good lord this is a cool car To get the photos to come thru set out the link like this Tried it, doesn't work. I've had a few goes at this now, I can't get it to do anyhting other than post a link. The imgur app is utterly rubbish. I tired the Flixr app before Imgur, it's even worse, the app does not work on my phone and cant upload more than 1 picture at a time via laptop. Getting rather annoyed about this now tbh, bah! If you're using a laptop on Flickr then I found it best to use the Internet browser rather than the app (which is meh) It's then one click to get the Bb image link. The Web one let's you upload huge amounts of images in one go. It's what I use for my threads. Loving the 205, and the new floor is a work of art. I wish we had more rally build threads on here as rally fab work is often a joy to behold! Looking forward to seeing this running.
Sorted it with Flickr now, thanks for the advice, enjoy the pics
Dec 17, 2021 11:40:57 GMT
More stuff; Modifying the bias pedal box to hydraulic clutch Full 3" stainless downpipe and exhaust Custom 40L boot mounted fuel tank Standard Audi shifter box, 205 steering column and sierra handbrake lever. Track day doors have been swapped for a mint set, which will be having electric windows (because the damn winders hit the cage x bars!!!) Fuel rail modified for AN6 fittings, have an Aeromotive FPR Rocker cover modified with 2 AN10 breather fittings and aluminium oil filler to replace the horrendous and leaky vag plastic cap Carbon fibre ECU mount, which actually was an ecu mount from a single seater Formula car Engine shiney bits/piping/filter/header tank
Are you planning to mount your centre pipe to the shell with rubber bobbins?
Are you planning to mount your centre pipe to the shell with rubber bobbins? For the time being yes. Exhaust wasn't finished in that pic it has extra bracing and another mount now.
Update, the car is now fully painted! Sorry not gotten round to sorted/uploading pics yet, but it looks mega! Will be starting the rebuild in a couple of weeks
Missed this until now, awesome.
Jul 25, 2022 12:28:19 GMT
Sorry for long time no post. Car came back to me at easter, engine and everything major is in. In the process of working through about a thousand snags before I get to the wiring
Jul 25, 2022 19:28:20 GMT
I've not been interested in rallying for many, many years but have to say, that is a beautiful looking car, I think it would equally make a devastating road car, Stunning and bookmarked, Nigel
Chris™
This is clearly filler material.
Jul 25, 2022 20:04:55 GMT
That's beautiful, nice work tidying that up and making it as good underneath as it is on top.
Will look out for the updates.
1989 Volvo 340 1986 Suzuki SJ413 2000 BMW 318ti 2006 Lexus IS250
75swb
Beta Tester
Club RR Member Number: 181
Great to see this back! Can't wait to see it done
Has to be one of the best (in my opinion ), cars on here. Love a wide body 205. I bought one last Sunday, not quite up to your standard though.
