Sept 11, 2022 9:46:56 GMT
I left enough space between the center two vents for the radio ( cant go any lower on the dash because of the AC unit ) Tack welded in & test fit. And checking the clearances with the AC unit in.
Sept 11, 2022 9:48:34 GMT
Thanks grizz. Glad you had a good trip...
Sept 11, 2022 9:54:59 GMT
jamesd1972
Club RR Member Number: 40
1960 Ford Truck. jamesd1972
@jamesd1972
Club Retro Rides Member 40
Sept 11, 2022 10:03:26 GMT
Lovely work as usual, nice A/C is the difference between a beater and a comfortable daily in my head. Wince a bit when the first thing people do is the A/C delete as it makes the world a better place sat in that traffic jam in the summer. James
Sept 11, 2022 10:03:41 GMT
With the AC unit, the hoses, tubes, etc. behind the dash, there was not going to be any space for a glovebox or a ashtray. So I cut away all the mounting points for them. And I made a panel to the shape of the glovebox door and ashtray ( gradually different from left to right...) Tack welded in. More later...
Sept 11, 2022 10:06:21 GMT
Thanks jamesd1972 . Yeah, I never had AC (or heat) in this truck. But being a black truck in Arizona, it will be nice to have...
Sept 11, 2022 11:47:26 GMT
Very neat! Looks like you could almost get away with a flat floor.
Sept 11, 2022 17:31:05 GMT
Thanks. Stock, it had a flat floor. But I had to put a little tunnel in because I lowered it so much, and I had to move the engine & gearbox up a bit for clearance.
Sept 11, 2022 18:43:44 GMT
Nice work, is that a Ford Capri in the background?
Sept 11, 2022 19:02:41 GMT
Sept 13, 2022 0:50:48 GMT
You do such nice work MShapes.
And your Capri is bad@$$ !
John
Sept 13, 2022 2:23:03 GMT
Thank you John.
Sept 13, 2022 21:11:13 GMT
Yep, as you Americans say - Badass!!
teaboy
Make tea, not war.
Sept 13, 2022 23:02:12 GMT
I'm not sure he is American, maybe he would say arme ezel?
Sept 14, 2022 1:12:31 GMT
I'm from the Netherlands, living in Arizona.
Sept 14, 2022 2:05:45 GMT
About that last vid.. That is some time ago, and I've steadily been dialing it in ( before and since that vid ) As you can see, a careful toe on the throttle pedal gave instant snap oversteer, so I'm guessing I had the "big" engine in it at the time. Which is a all aluminum racing engine, 400 cubic inch - 6.6 litre ( the block is from Donovan ) based on the small block Chevy, with Brodix heads It was once used in a outlaw sprint car ( random pic off the net ), where it had become illegal when they switched the rules back to iron blocks. It got it as a used short block, with a steel bottom end and forged pistons. I lowered the compression ratio to switch it from alcohol to gas ( petrol to you guys... ), and detuned it a lot for torque and reliability ( down to about 515Hp ) It has quad 48IDA Webers, and a 180 deg exhaust system. Since that vid I've made a lot of progress in how it delivers its power ( completely redid the throttle linkage into a 2 stage system that gives a lot of pedal movement for the first 1/2 of the throttle opening, after which it snaps open for the last bit of pedal movement). Which made a big difference in how I could get on the throttle at corner exit . I've made big improvements in the corner entry understeer too, but there is still more room for improvement there. ( it has gotten power steering, a quick rack, and modified geometry for corrected rollcenter with no bumpsteer) A big improvement was getting rid of the Super T10 4 speed. I got it out of a big block Pontiac Trans Am, and it was fine on the street. But on the track, trying to shift quickly, it felt like it belonged in a dump truck. It was fragile too, I'm about 3 rebuilds in... I replaced it with a straight cut close ratio Jerico dog box, which does lightning quick shifts ( clutchless even, if you're not paying the bills...), and can handle a lot more torque. I went through several different clutches/ flywheels/ throwout bearings/ bellhousings ( including a 3 plate Tilton ), untill I settled on a 10.5" aluminum flywheel with a regular "street" friction plate. Basically upgraded street/strip Big Block stuff.... Its a fun car... More info here. forum.retro-rides.org/thread/197559/1973-capri-v8
Sept 17, 2022 1:17:23 GMT
braaap
Sept 17, 2022 5:14:47 GMT
Excellent job! Tack welded in & test fit. Just in case You want to replace that modern looking radio at some point: look out for this one, I can really recommend it, it can handle a lot of sources except cds and sounds quite good. Best thing is, You can get it really cheap, I paid 16€ incl. postage, but some sources sell it for 50€s.
Last Edit: Sept 17, 2022 5:16:04 GMT by braaap
Sept 17, 2022 7:13:00 GMT
Thanks, but that radio has a story. It was a birthday present from my wife, many years ago. I never got around to putting it into the truck, which annoyed her. And then, in time, it sort of became a running joke. But now it finally it will have its day...
Sept 17, 2022 18:19:12 GMT
Just a silly grin to add.
Been and will be busy, no car time right now.
Thankful for the updates others are doing right now.
Progress is Progress.
