Is that Veroboard? I think I've got some in the loft from the decades I was known as 'Mr. Blobby'. Not that I was a pink, bald gimp with multi-coloured spots but because of my sadly lacking soldering 'technique'. Things have not improved Yes it is Veroboard! Random Mr Blobby moment: I didn't know there was a Mr Blobbyland / Crinkley Bottom theme park which had been abandoned. Until quite recently most of it was still there all overgrown.
awoo
Do a skid!
Have been down with Covid this week, so no progress on anything. However, have had the valve amp on keeping the living room warm and been listening to all sorts from 60s rock to the BBC Synth Britannia playlist to contemporary techno. Really wanted to hear a bit of Jimi Hendrix so obviously hit Experience by default. I need to get up in the loft and see if I’ve still got this on CD because the quality on YouTube doesn’t do anything any favours: Started with the EZ81 doing the rectifying and obviously flicked it over to the diodes to make sure everything came through! I don’t think it makes a massive difference, but it does buy another 20-odd volts on the HT which maximises the output. Music from the same era as the amp sounds great! My 4 year old’s current favourite is a bit of Jon Hopkins (he likes the video). Won’t be to many people’s tastes but I like a bit of techno/synth/electronic and this is really full-sounding: Of course, one thing led to another and he needed introducing to Yello - The Race: Orchestral Manoeuvres, just because:
jimi
Really wanted to hear a bit of Jimi Hendrix so obviously hit Experience by default. I need to get up in the loft and see if I’ve still got this on CD because the quality on YouTube doesn’t do anything any favours: Great looking line up of valve gear and good musical taste 👍 My username comes partly from the diminutive of my name and a tribute to the MAN, I've used it that way for over 50 years, it was sign written on the side panels of my Lambretta back around 1967/68 I'm pretty sure I have the 45 single of "All Along the Watchtower" (and Hey Joe & Purple Haze) in the attic,I need to get up there as well, my vinyl has been up there that long I've forgotten all the stuff I have 🤭 Apologies for the thread distraction 😉
Last Edit: Dec 9, 2022 22:56:28 GMT by jimi
Apologies for the thread distraction 😉 Not at all, love a bit of music talk! My dad had stacks of 60s rock singles and LPs but I think over the years he’s moved them on. I put a phono stage on the preamp just in case, but I haven’t had a record player for decades.
Dec 10, 2022 19:34:56 GMT
To make a system sing you can't go wrong with Yello. The Album 'Baby' is teriffic, Jungle Jim or Ocean club sound amazing with the volume cranked and really work your system.
Dec 13, 2022 12:45:30 GMT
Wired in some RCA inputs and two pots for the levels: Next step is to put a signal through it and estimate the actual gain on the ECC83. Then try to figure out how to get the negative part of the signal through the diode, which is where it seems to be getting stuck at the moment.
Last Edit: Dec 13, 2022 12:46:38 GMT by Jonny69
Dec 14, 2022 11:57:32 GMT
Ok, I got this working. It just needed a reference to 0V adding in and now it works. I tested this by patching in a 1M resistor with a croc clip while putting a 100mV 1khz signal in the input: That went from the coupling capacitor output to 0V which was a nice easy fix. You can see the fan on the tube on the left is wide - that's because the correct voltage is now getting through. I didn't have two 1M resistors for on the board, so 820k resistors had to do: And that meant with a music signal on the input, the fans dance to the music: A quick video with music going through it but no sound: I'll need some piggyback connectors to be able to run it and have sound at the same time. I wanted to put two sets of connectors on the back but there isn't quite space. Note how the two tubes are slightly different in real life. Both face slightly different directions and the colours aren't the same! Quality control at its best. Gain-wise, with 100mV input at 1khz, the ECC83 puts out 7.3V. So the gain is about 70x. Full fan appears with 460mV and 29V output. I haven't put a scope on it, but I suspect it's clipping at that point. I'm glad I opted for an ECC83 over an ECC81, because the signal is only just high enough to drive the circuit. I think when I put it on the preamp at home, it might struggle a bit.
Last Edit: Dec 14, 2022 11:58:57 GMT by Jonny69
jimi
Dec 14, 2022 16:12:40 GMT
That's pretty cool, I like it, it's quite subtle
Last Edit: Dec 14, 2022 16:13:12 GMT by jimi
Dec 15, 2022 15:17:52 GMT
Last month when the Ukrposhta postman visited, I tested out the IV-6 VFD tubes but not the IN-3 indicator tubes or the MTX-90 tubes. The IN-3 tubes are indeed similar to the IN-35 luminophore lamps on page 7. They look ever so slightly different. They have a sort of reflector cup and the glass is smoked like a nixie tube. The difference for running is the IN-35 is around 5mA at 240V but the stated voltage and current for the IN-3 is lower. Again, I don't fully understand the datasheet. It shows an anode and a cathode side, which presumably relate to the bits inside that look like a plate a reflector. Two voltages (90V and 55V) are stated, which might be the trigger voltage and minimum voltage to sustain the lamp. Current 0.2mA compared to the IN-35's 0.5mA. I decided to hit them with 240V on the breadboard and limit the current to 0.2mA, which meant a 1.2M resistor. It lit but was a bit dim, so I added another one next to it with an 820K resistor So as far as I can work out, they're just a lower power indicator lamp, maybe which fires at a lower voltage than the IN-35. It can be viewed front-on or from the end. Only comes in orange. I think they were used as the dots in nixie display equipment, clocks etc, since the trigger voltage is the same. I've got 25 of them. Next up are the MTX-90 thyratron tubes... These aren't an indicator lamp like I originally thought but they do light up when triggered. A thyratron is in fact a type of switch and these tubes can perform a number of functions, most of which I don't understand yet. It has three pins. There's an anode, cathode and grid. High voltage goes between the anode and cathode, then when sufficient voltage is applied to the grid, the device switches on (and lights up). It doesn't need much, because the grid is sensitive enough to be used as a touch-sensor. This is what it looks like - the tube is about 30mm long and 10mm diameter: Here's a video showing some of the things it can be made to do: I'm guessing it could do simple logic as well. I have ten of them. No idea. The solder balls aren't solder either, they seem to be solid and tinned. I've made it easier to play with one by soldering it to some PCB header pins: So, uh, yeah. Still got no idea what to do with these so watch this space I guess!
Dec 15, 2022 16:11:30 GMT
Yeah, the MTX-90 is going to need a bit more figuring out before I'm happy with it. Decided to knock the touch sensor up on the breadboard: Taking full note of the fact that it's directly rectified mains and it's not completely clear whether the pinout is as it says in the datasheet (see above), I proceeded VERY cautiously and wasn't keen to touch anything. Mine just lit up, so something isn't connected correctly. The grid seems to be showing 170V so I'm not touching anything yet, even through a 1M resistor. Pulling the 'grid' pin high or low did nothing so I'm guessing the pinout in my post above is not correct.
Dec 16, 2022 16:26:24 GMT
So a couple of posts ago I said I was worried about the input level for the VU meter well ive literally had two nights no sleep thinking about this and how I might end up having to deal with the whole Christmas break without a properly working VU and its been getting me down and this morning I decided to call the doctor because I don't want to slip into a depression over this and he goes to me yeah I think ur gonna need an op and I was like WHAT and he goes hold on let me finish I think you're going to need an op AMP on the input to bump the voltage up a bit. You know, from 1990s A Level electronics, remember? Well, sort of. I had a rummage in my scavenged box of outdated bits at work and indeed found some 1990s 8-pin DIP dual op amps. Dual 741s, no less, the real deal! I present to you, the MC1458: Perfect. One side for left, one side for right. Lunchtime project time before I finish for Christmas. So, rough plan. Tap into the 6.3V heater supply. Bridge rectify it and split it down the middle with resistors to make about a +/-3V supply with 0V in the middle. Make a pair of non-inverting amplifiers with a gain of about 5x which should give me plenty of extra input voltage. Don't want to amplify as much as 10x because that much might make adjusting it difficult and 5x gives me plenty of headroom with the low supply voltage. An additional bonus of having an op amp on the input stage is if the VU meter introduces any hum into my system through the signal lines, the op amp will effectively isolate the rest of the circuit and eliminate any hum. It's not fully tube, but it is fully in the spirit of my bodgey builds made with outdated toot. Non-inverting amplifier for those who have forgotten (like I had): Equation for those who have forgotten (like I had): From here, many thanks random website. I used a 180k resistor for RF and 39k resistor for R2, which should give a gain of about 5.6. I also found a random/handy DIP-sized bridge rectifier which made my veroboarding much easier. I also added on a couple of 100k resistors to divide in the 0V point and a couple of 47uF smoothing capacitors and this is what I ended up with: Testing on the analogue bench supply: Obviously it didn't work first time - I'd put the two resistors on the right-hand channel round the wrong way so I only got a gain of 1.25. Glad I checked. Once I'd swapped them around, with an approximate 100mV DC input I got an output of around 540mV from each channel. Spot on.
I didn’t need the additional op amp stage in the end; the preamp output is sufficient to max out the magic eye tubes during full bits of music. Hopefully this video will work: I wanted to post a video with some proper music playing but I kept running into YouTube copyright violations. Really annoying. So this is George Street Shuffle which is one of those YouTube no copyright music pieces for content creators. I’ve got it propped on top of the amp temporarily so I can run it. When I get an RCA splitter I’ll be able to patch it in properly and it can sit on top of the preamp like this: It's properly turned into valve mountain in that corner. Total of 14 valves burning away when it’s all switched on!
jpr1977
Club RR Member Number: 18
Dec 22, 2022 12:18:22 GMT
It's properly turned into valve mountain in that corner. Total of 14 valves burning away when it’s all switched on! You wont need any heating in that room when its switched on...
Last Edit: Dec 22, 2022 12:18:43 GMT by jpr1977
Dec 22, 2022 13:29:55 GMT
You wont need any heating in that room when its switched on... Yeah it does get pretty toasty over there!
jimi
Dec 22, 2022 23:22:02 GMT
How's the x-former handling being enclosed ?
Last Edit: Dec 22, 2022 23:22:51 GMT by jimi
How's the x-former handling being enclosed ? On the amp? It’s ok as long as I don’t run it too long. It does stabilise, but it’s way too hot at that point. Things like I don’t like running capacitors that hot (I can’t remember if the ones I used are 85°C or 105°C rated) and the resistors will be all out of tolerance by that temperature. I can run it for about an hour, so I’m thinking some passive cooling will be sufficient. It needs to shift around 30-40W of heat. I’m planning to open up the bottom panel, drill a number of ventilation holes around the fronts of the transformers and then open up the backs of those top covers. That should allow enough airflow through from bottom to top. I’d prefer to slot everything but I don’t have a mill. Holes I think will look a bit amateur. Second best might be to bond a mesh on the inside. It just needs to be stiff enough and carefully placed so that it can’t get pushed onto anything at voltage by wandering little fingers (I have young kids). That’s why slots would be best but I can’t think of a way to do it. Another option could be a couple of 5V fans blowing through, but I’d prefer the simplicity of the passive option. It’s one less thing to fail and I’m not actually sure there’s enough space.
jimi
Dec 23, 2022 21:12:34 GMT
I'm with you on the slots, look much more professional IMO similarly with passive cooling. Although sometimes active is the only way, what I've done in the past is to put in a 12v fan but run it on a lower voltage (probably still run at 5v) I had good results with a fan at the bottom sucking air in and vents at the top. I installed this one (its 12v and running on 12v) on my Topfield PVR, with the PSU and HD side by side they tend to run hot and the original caps on the PSU were poor quality, they normally fail after a couple of years and cause all kinds of problems with the PVR operation. Mine have all been replaced and I put the fan in to try and prevent future problems,it's virtually silent and reduced the HD temps from average 53degC to 30degC according to the HD S.M.A.R.T. info. Must have worked PVR is still running trouble free over 11 years later and its on virtually 24/7
This is a difficult thread to know where to start because it’s currently got no real direction. It’s been on the back burner for a while, brewing in my head and maybe reignited as a side-interest from my valve amp projects. TLDR is these first few posts are going to be a mess as they’re going to be a dump of ideas, inspiration and things I’ve been looking at on the internet.
Synth music has been part of my life since day 1 as I grew up through the 80s and most of the music was electronic. Brief interlude in the 90s when I was into rave/hardcore/jungle but the influences were constantly there, with most of the non-sampled sounds for almost all techno and trance music coming from the 808, 303 and 202 synths. Then came a resurgence around 2010 when synthwave came onto the music scene and the old-style analogue patch synths came back into popularity. The synthwave scene actually held on for quite some time, but much has now evolved into more manually-generated synth music on patch synths, with trackers and a lot of knob-twiddling.
Some key things: -This will be a modular knob-twiddling project, not a keyboard with a built-in synth -I don’t know what I’m doing but I do know I’m already way out of my depth -This will mostly be designed and built from scratch. It simply makes more sense to me to do it this way because it takes longer and costs more. Every time. -I may have already bought some things -I also have a drawer full of old op amps, 555 timers, counters and various other bits of completely out-of-date analogue electronics -I like valves -I’m not a music-maker and I can’t play instruments -Ultimately, this is really going to have no use other than to make funny noises, take up a load of space and bleed my bank account
Key words: Robert Moog, Wendy Carlos, Eurorack, Look Mum no Computer, unattended music, oscillators, Live at the Necropolis: Lords of Synth etc etc
Some videos.
Wendy Carlos. She did the music for Clockwork orange and Tron. Her early music was generated with a Moog synth and she helped Robert Moog develop them:
Run-through of a Moog synth (probably better ones out there, but you get the basics):
Lords of Synth:
