2001 Peugeot 106 GTI VTS Project
Started its life as a 1.1 with 78k miles on and now has a 1.6 VTS engine in it (Still registered as a 1.1) The car runs but as you can see it’s an unfinished project (engine has 70k ish miles on)
I’ve put a lot of time and money into this but unfortunately I need the space so it has to go.
It’s had a LOT of work done, It’s basically been rebuilt from the ground up, underneath is all solid with no rust.
It doesn’t need much to be ready for an MOT. It needs the indicator and wipers looking at, fluids need bleeding, gear links need connecting, fuel line needs to be bunged off/return connected, radiator fan connected, throttle cable adjusting.
Price wise I know what I can get if I break it up so do not insult me with low offers. The list of new parts and other bits this has had comes to around £5000 so please bare this in mind.
It also comes with a LOT of spares which includes - Wiring loom, Clutch, Flywheel, Manifold, Lambda, Downpipe, Gearbox, Driveshafts, Steering Wheel, Airbag, Coilpacks, Fuel lines, Engine Mounts, Inner wheel arches, Clocks, Full set of steel wheels with tyres, Box full of odds and sods
Work that has been done/needs doing is as follows -
Rear dewipered and bunged off
Blue painted brake callipers
Bee sting aerial (needs fitting)
New blue track style door straps
106 GTI front and rear bumper and comes with full arch kit, side skirts and spoiler which just need fitting (spoiler needs painting)
New lowering springs
New custom track style light door cards
Refurbished GTI raptor alloy wheels with good tyres all round
Engine strut brace
Replacement rear axle which has been striped, cleaned and painted
Underneath has all been cleaned and waxoiled
Replacement boot rubber
New Bilstein shock absorbers all round
2 yellow Corbeau bucket seats (need fitting)
New JVC speakers
OMP bucket seat mounts (need fitting)
Blue show cage
New gear links (need fitting)
New front strut top mounts
New drive shafts
Quick shift (needs fitting)
New lower arms
New steering wheel boss
New genuine Motamec blue suede deep dish steering wheel
New tie rod ends
Saxo VTS engine with loom
Polished engine covers
New 3 piece LUK clutch
Just had a full service including new NGK plugs
New radiator
New timing belt and waterpump
New blue floor mats
New thermostat and housing
Full stainless exhaust system including 4-2-1 mainfold, decat
New radiator fan (needs connecting)
New Powerflex exhaust rubbers
New fuel pump
New front brake discs and pads and new rear shoes and hubs
Stone chipped arches
New throttle cable (needs adjusting)
New Ramair intake with blue breather
As you can read from the description no expense has been sparred and it just needs finishing off. It will be a fun little car once finished and prices are only going 1 way.
I can also get the standard interior if the buyer wants.
If you have any questions please contact me on - 07415299858
Will consider a swap/part ex.
Thanks
Price - £2500
Location - Norfolk
Pictures -
Engine strut brace
New JVC speakers
Blue show cage
New drive shafts
New lower arms
New tie rod ends
New radiator
New blue floor mats
New fuel pump
Thanks
Price - £2500
Location - Norfolk
Pictures -
