1992 Mercedes 190E M111 2.3 Kompressor 6MT
**UPDATED MOT 01 Jun 2023**
116000 miles on chassis / 108000 miles on engine
Reduced£8000 £7500 negotiable
Professionally built by Scott Automotive Hexham NE46
M111 2.3 Kompressor engine + 6 speed manual swap
Drivetrain from donor car Y reg CLK230k
Custom propshaft
Custom full stainless exhaust system
Performance air filter
H&R lowering springs
Push button engine start (ignition on CLK key as installed in the original position, engine start button on cigarette lighter)
16in steelies with W140 wheel trims
Short clip upon completion / being a bit silly in the workshop
Car started life as a base model 190E 1.8 manual (still listed as a 1.8 on the V5)
MB 752 Carrara Grey (rare colour)
Grey fabric interior
No sunroof
No A/C
Manual windows
Car had been waxoyled underneath from new and is therefore pristine--in fact the original plan was to build a drift car with a Pandem widebody kit on but the mechanic couldn't bring himself into butchering the wings which were (and still are) in remarkable condition. Running approx. 250 bhp and goes like stink, with the soundtrack to match.
Good Points
The way it drives and sounds--sure way to bring a smile to your face, often turns quite a few heads and generates thumbs-ups.
True sleeper--subtle, understated looks but packed with performance. Best Merc era in my opinion, over-engineered, built to a brief, but not to a budget.
Rust-free--as said the panels and underbody are the cleanest I've seen on a 190E, none of the rust issues in the usual places or beyond.
Bad Points
Original speedo and tacho do not work, however a GPS speedo unit has been installed. The other gauges (water temp, oil pressure, fuel, clock, warning lights) do work correctly.
The diff has been replaced like-for-like as the welded item did not suit normal daily driving--of course could be welded if intended to use as a drift car.
Selling as I feel like I'm doing it a disservice and couldn't realise its potential as a drift car, as well as the proverbial having too many projects on hand...
Located in Newcastle-upon-Tyne
£8000 ono / negotiable
Please Whatsapp / ring 07503408006 if interested / any questions.
Reduced
Custom propshaft
No sunroof
No A/C
Manual windows
Good Points
Bad Points
