Nathan
Club RR Member Number: 1
1957 Standard 8 - Winter upgradesNathan
@bgtmidget7476
Club Retro Rides Member 1
The 1500 engine and the right rear axle ratio will make a huge difference. Is there room for an overdrive gearbox? We could make room to fit one at the very least. There seems to be a crossover in the Herald where we could use the internals to align the gearing a little better, I'll investiagte this further. I have noticed a gearbox under the old bench which I think is a OD 1500 Triumph box, not sure where it came from though ahahah
logicaluk
Aug 30, 2024 12:30:04 GMT
Iirc the best manifold choice is the single su Toledo 1500. I think I have one for the herald 1500 I'm trying to build. D
Aug 30, 2024 17:13:33 GMT
Don't bother with all that engine cradle snatching business. Find your self some Viva HA engine mounts -they bolt to the Standard chassis mounts and line up with the later style Triumph engine lugs.
Hopefully you have strengthened the bottom end in your built 1500 - even a 4.11:1 diff won't be tall enough for long life of a standard 1500 lump. I have modified Dolomite internals in my rear axle and a 3.63 from a 1500 Spitfire.
'57 Austin Cambridge A55 1800 Overdrive '50 MG Y-type (In build) '56 Standard Super 10 (In build) '04 Seat Leon TDi 130 (Wet weather runabout) '03 Citroen Berlingo HDi (Parts hauler)
Aug 30, 2024 20:51:50 GMT
I have seen one with an overdrive box.
Last Edit: Aug 30, 2024 20:52:27 GMT by pollystag
