Bit of advice guys please. I've been meaning to buy a Dremel for sometime. Now I really need one for cutting and grinding alloy , I'll need an extension shaft also so I presume buying a kit is the way to go? Something like the Dremel 3000 multi-tool, flexible shaft attachment and 25-piece accessory kit.
Is this o.k. or am I better off getting something else? Cheers.
Last Edit: Aug 7, 2022 23:17:30 GMT by Woofwoof
they are super handy tool i would be lost without mine get the speed click attachment if it doesn't come with it and a wheel suitable for aluminium
Club RR Member Number: 160
Which Dremel rotary tool?Rich
@foxmcintyre
Club Retro Rides Member 160
I had the Dremel 3000 for a few years but killed it recently, it’s had some use to yea. Replaced it with the Ryobi One+ multi tool that has a motorbase and a shaft. I rarely use it away from the bench so it’s wall mounted which is dead handy but I can easily slip it off the mount and take it anywhere being cordless. If you are on a cordless system see if the makers do a multi tool. Otherwise I can’t complain about the Dremel.
slater
Club RR Member Number: 78
Which Dremel rotary tool?slater
@slater
Club Retro Rides Member 78
What do you actually want to do with it? Dremels have thier use but think porting a chainsaw rather than porting a mini.
I have an original dremel with flexi attachment which is still going strong 25 years later. Not sure if modern ones have gone down hill or not tbh!
