Hi, this is a nice solid rare ST24 in medium steel blue.
Mot till 1st June 2023
126k miles
This has had quite a bit of work done in the last 2 years including the following:
Exterior -
New Headlights.
Nightbreaker headlight bulbs.
New door weather strips.
Drivers side inner and outer sill replaced.
Drivers side rear arch replaced.
Drivers side front wing replaced.
Rear lower seatbelt anchor points welded.
This makes it nice and solid now.
Also fitted are a set of very rare ‘02 American market Focus SVT 17” wheels with matching tyres.
Brakes -
Focus ST170 Front discs (Black diamond combi).
Mondeo ST220 Front calipers (powder coated silver).
Mondeo ST220 Black diamond predator pads.
(rear brakes untouched)
All 4 ABS sensors replaced.
Suspension -
New front lower arms/wishbones fitted with Powerflex poly bushes.
New drop links.
New rear lower arms with Powerflex poly bushes.
New rear trailing arms.
Engine -
Completely standard 2.5 V6.
New exhaust flexi pipe.
Recent full service including spark plugs, oil and filter.
New alternator and auxiliary belt.
IMRC replaced with second hand item.
ABS pump replaced with a second hand unit.
Interior -
ST200 black leather Recaro seats in excellent condition.
ST200 carbon dash surround.
All 4 door cards replaced.
Pioneer DAB headunit with Bluetooth/usb connectivity.
VIBE 5x7 speakers in all 4 doors.
ST220 gear knob.
Perfectly working air conditioning which was regassed last year.
This was a small restoration project and is now a great base to continue.
Negatives -
The handbrake light sometimes stays on. I believe it may be the handbrake sensor that needs changing.
The headlining is slightly saggy. It has been pinned up for now.
£2300
Located in Sheerness, Kent.
Bank transfer preferred.
07908 158 336
Thanks
Tom
126k miles
Exterior -
New Headlights.
Brakes -
Suspension -
New drop links.
Engine -
Interior -
ST220 gear knob.
Negatives -
£2300
07908 158 336
Thanks
Tom
